ycc lg 1550 or conrad lg 1750 Options · View
lainy
Posted: Monday, February 16, 2009 6:56:22 AM
Hi
I'am undecided on which model to buy... and thoughts?
does the 1550 come with a rear mast?
cheers.
Posted: Monday, February 16, 2009 7:22:00 AM
lainy,
this has been discussed recently: LG1750 or LG1550
I am fairly certain that the Derrick mast does not come with the model. It has be bought seperately.
lainy
Posted: Monday, February 16, 2009 7:44:17 AM
cheers!
birdman
Posted: Monday, February 16, 2009 11:06:23 AM
Hi lainy,
As you may have read in the other post re same subject, if you have the funds go for the LG1550 IMO a far better model detail wise. I can also confirm that the LG1550 does not come with the derrick mast, but the derrick mast and luffing jib from the LTM1800 will fit and can be bought separately also you can get boom extensions for the LG1550.
Hope that helps
Steve.
Cranes Etc
Posted: Monday, February 16, 2009 11:28:36 AM
Gaz
Posted: Monday, February 16, 2009 11:49:17 AM
Hope that helps
Steve.
The luffing jib for the LTM1800 is different than the LG1550, there will be a luffing jib for the LG. the LTM one will not fit, however the derrick mast will.
Gaz
Kristoffer
Posted: Monday, February 16, 2009 11:52:43 AM
Hi Gaz
Only partly correct. The LTM1800 luffing jib equals the light luffing jib for the LG1550. The heavy jib for the LG1550 does not fit the LTM1800.
Regards
Kristoffer
Kranliste
Christian
Posted: Monday, February 16, 2009 12:47:59 PM
LG1550 with heavy jib (jib levers made out of strutwork, angle of jib is changed between jib levers)
http://www.kransite.de/-poster/003.JPG
LG1550 with light jib (= LTM1800 jib is identical, jib levers made out of full steel material, angled of jib is changed at the uppperstructure
http://666kb.com/i/ak2sgrbt155ban0pd.jpg
LG1550 with heavy jib and light jib parts on top of that
http://www.kranliste.dk/billeder/spacelifter.jpg
LG1550 with SLK foldable main boom system (no thats not a jib, once the boom is up it stays at a fixed angle)
http://freenet-homepage.de/upseven/nolte/Compressed_0003.jpg
Gaz
Posted: Monday, February 16, 2009 1:07:35 PM
I stand corrected, handy to know. So i can put my LTM1800's luffer on the LG1550?
Gaz
CAT320DL
Posted: Monday, February 16, 2009 2:15:08 PM
Go for the LG1550 since, you can add more things to it, and will not be able to add things to the LG1750. That is my opinion if I were to get one of those which I will not since, it is to expensive and I just do not like them, which is my opinion.
Cat 966f
Posted: Monday, February 16, 2009 2:35:14 PM
Did'nt you say that you have bolth of them. Can you get some pictures of them for me?
-Vinny
http://www.heavytruckphotos.com/
CAT320DL
Posted: Monday, February 16, 2009 2:40:55 PM
I never said I had both of them, Vinny so why you lieing if I do not have them? I do not even have $2,000 dollars so stop lieing, and stop trying to get me kicked off the froms.
Cat 966f
Posted: Monday, February 16, 2009 3:03:18 PM
You have a PM
-Vinny
bigcranes
Posted: Tuesday, February 17, 2009 4:46:41 AM
I have the LG1550 with the derrick, the same as the LTM1800, but as far as I can tell you can not use the derrick and the light jib together. If you want a derrick and jib for the LG1550 you will need the heavy jib wich is not out yet, you can use the light jib with out a derrick though.
Sorry if that is confusing.
Mark
I will post some pics later in the week
Mark L.
Christian
Posted: Tuesday, February 17, 2009 5:47:48 AM
Mark
that is correct. it would also not make too much sense to put on the derrick boom when you just have the light jib on top. everything you can pick up with the light boom can be tackled by using just the main boom alone, no need for a derrick.
LiebherrDemag90
Posted: Wednesday, February 18, 2009 8:20:38 AM
Hi guys, i just got a reply from YCC. YCC stated that in order to use the W(heavy luffing jib), we would need to buy the S (heavy main jib) as well in order to fit. Both these items are sold separately(in the future).
It will cost me a bomb for a full setup. Sad I was wondering, would it be better to get the LG1750, since i wanted a full setup? I'm only a student, so i got quite a limited budget. Or would it be advisable to purchase a base model of the LG1550, scrimp and save again, then purchase the boom options? What are your view guys? Your help would be appreciated.
bigcranes
Posted: Thursday, February 19, 2009 3:07:34 AM
I have several of the YCC madel and they are VERY nice! I do feel that the LG1550 for 850-900 USD is a very good deal. If you want the "full set-up" as you say, you will probably be out at least 2000USD. I have 900 in the basic crane and 450 for the derrick so thats 1350 and the heavy jib will be at least 650. So if you want a nice crane that is a more complete package, get the 1750. You should be able to get one shipped for 1000.00US
as always, IMO,
Mark
Mark L.
LiebherrDemag90
Posted: Thursday, February 19, 2009 3:39:45 AM
as always, IMO,
Mark
Thanks for the insight. =D I read the review on Cranes Etc. for the LG1750 and it stated that it does not come with reeving guide for the hooks! d'oh! I'm new to crane models, hence i have no idea how to reeve a 2 sheeve hook, let alone a hook that can lift 750tons. Silenced Does YCC include the reeving guide for the LG1550?
bigcranes
Posted: Thursday, February 19, 2009 4:21:29 AM
The hook block trick is to hold it stationary while you reeve it, camera tri-pod etc. I made an adjustable wood pole that I clamp the hook block to an reeve away. As for the diagrams, YCC has improved theirs a bit, and I don't know about the conrad one, the old LR1750 sucked. Just start with the small hook on the conrad 1750, it's not that bad.
Mark
Mark L.
LiebherrDemag90
Posted: Thursday, February 19, 2009 10:36:23 AM
Mark
Thanks Mark for your ingenious method. I've never thought of using a tripod! I guess i would return to YCC, since Conrad still uses quite some plastic parts in their LG1750 and i've got lots bad experiences with plastics.
Anyway my other qsn would be, can the YCC's LG1550 lift roughly 900grams? My mountain bike wheel weighs around there and i was wondering if i can use that to simulate the LG1550 lifting a kiddy ride of Ferris Wheel.
