CAT977L wrote:dosent that make a wider base on that and you should make the tracks go n and out for transport that would be slick.
Sure, on some of the real machines the U/C are varriable, but for model purposes since HRD the boom does not come apart I see no reason to give the U/C the ability to go into transport mode.
On the original model by HiMoBo, the U/C was varriable, but rather flimsy so I replaced it with the original U/C from the 345B MH.
-Eric W. Pioszak: Operating Engineer
Northwest Demolition and Dismantling
Only HACKS use thumbs for Demolition
