Quote:Do you guys think I should do the power boom or not? Go big or go home! Looks great though
Great work jason! I saw the pic with the 5500 and I was thinking (okay, so it's big but not thaaaat big) but when your children were under it WOW
-John
Thanks guys I really like how it is turning out. Brandon I Like your thinking. I will probably go with power boom. I took crane out side the other day to get some pic and had a failure on some brackets. So I took the crane apart to repair. Since I was painting some other projects I painted so on the crane. Looks better with paint. I am thinking about doing these for sale. Would be a small number made. Will be a base machine and there will be add ons available. Once the prototype is finished I have one big project to finish and I will start on these. Hope you enjoy Jason
That looks awesome especially with the paint can't wait to see it done
Great job! Sad it's not made from metal. I will surely buy one, if it.
My collection: http://fotki.yandex.ru/users/umf2009/
Rediculously good!! Im sure you will get alot more orders for what you had envisaged.looks extremely sharp and you don't have to worry about licencing so I say get casting and churn 'em out,how many people are waving fists full of money waiting on an LR1300 or CC8800 Twin to appear.
Hey guys got some more done. I have designed a systems to run duel stacks of weights on main crane. Here are some pictures Single stack double stack Here is the frame
Added more paint as well
Finally for some serious lifting. .. Now I need to mold and cast counter weights and build the super lift tray. Jason
It's coming along really nice and good to see it's almost done
Looks incredible Jason! Good job.
Joined: 7/20/2005 Posts: 336 Location: Alberta Canada
Awesom work, any plans to make it R/C? Icing on the cake I would say... I like the expanding CW idea, does that eliminate the need for a superlift tray?
Ok have done a lot since last update. I have started painting the model. I am going with a darker gray undercarriage and a yellow upper and boom. Here is the undercarriage, you can see the catwalk still needs flooring and a set of stairs Here is the power unit / cab and center section of upper attached
The counterweights have been redesigned. I did not like the bulky blocks so i designed them in 3d and had a few printed. I designed them so i could add 1/2 washers for weight. They will be on the bottom and will not be visible. Here is the base plate the weights will sit on
wow.. great work, that is all
Joined: 8/24/2006 Posts: 2,185 Location: Grapevine, Tx
Great job Jason, the crane looks awesome Jeff
Incredible work. Well done!
More pics. Have not updated in a while Suspended tray Long main boom
Latest th8ng is the addition of led lighting. I design a power control module as you can see the mod fits into the engine compartment Video of light test. The power harness for the boom is on a power harness strung on a reel to accommodate different boom configurations http://youtu.be/qc7oAn64Grc">vid
