Joined: 1/20/2014 Posts: 352 Location: South of VA, North of SC
Hi all, wanted to see if any one had any ideas on how to make or where to buy some 1/50 accessories. I want some 5 gallon buckets, caution tape (can just be some sort of safety tape), tools, welders, and other accessories you would find on job sites and in yards. Thanks in advance!
...Dylan My Instagram: Cat330DL_Man
I needed a 5 gallon paint bucket for a roll off dumpster that I built. Here's how I made one: I used my cordless drill as a lathe to turn a taper in a piece of plastic tubing. I used a triangular file to cut grooves to hold 0.020" rod to form the ridges in the pail. I placed it in the dumpster and painted it up.
__________________________________________________________________ Tom It's pretty sad when the only modeling tool you own is a box cutter. If the only tool you have is a hammer, you start to see every problem as a nail. Abraham Maslow
Thanks RI Craneman! Looks really cool in the dumpster!
I made some grade and station stakes with the halves on toothpicks and some thin strips of orange paper.
Thanks ethan, don't need grade stakes as of now, the dio is packed up I'll keep those grade stakes on my mind!
Joined: 2/19/2014 Posts: 55 Location: Chesterfield Va USA
Does it have to be 1/50 scale? 1/43 scale seems to look ok.
1/43 and 1/48 will work, just has to look right
