Due to a planned DOT bridge installation, we needed to temporarily re-route an existing 138kV transmission line. Since it is a temp installation, we went the cheap way - 60' sticks welded together. Half inch thick, 24" diameter and 120' high.Demag 395 handled the lift. It is about the largest hydraulic we have up here...Big chunk of steel - about 15,000 lbs I believe...The other install was bit trickier - we had to go across the highway.
In case you ever need it, the pipe weight formula is: Wt/Ft = 10.69*(OD - Wall Thickness)*Wall Thickness So that pipe weighs 125.607 lbs/ft. So yes, 120' of it weighs a little more than 15,000 lbs Cool pictures. Would have liked to see that weld.
Thanks for posting ulf. Looks like winter has disappeared up there? Ken
The pole across the road could make an instant drop top car.
Joined: 8/9/2002 Posts: 996 Location: worthington, ohio
Great pics, THANKS for sharing.Have to agree with Ken, very nice weather.
Dave
kcmtoys wrote:Thanks for posting ulf. Looks like winter has disappeared up there? Ken Not much of a winter up here this year - I believe we shipped it all to Boston.
