Joined: 11/23/2002 Posts: 296 Location: CAPE TOWN SOUTH AFRICA
Joined: 11/15/2003 Posts: 1,145 Location: North America
Man; I'm so glad you posted as nobody could have found this without you!
Joined: 1/6/2006 Posts: 250 Location: Abingdon, Virginia
What advantage is there of this large ADT over a 60 ton capacity rigid frame dump truck? There maybe be some specific uses for a truck like this Bell 60 ton capacity truck, but I don't see any right off of the bat.
Joined: 3/30/2011 Posts: 556 Location: Healdsburg CA.
Want a 9 wrote:What advantage is there of this large ADT over a 60 ton capacity rigid frame dump truck? There maybe be some specific uses for a truck like this Bell 60 ton capacity truck, but I don't see any right off of the bat. When I talked to the guys the their booth at the Conexpo, they were telling me they designed the truck with mine development in mind, where you'd need the maneuverability and the ability to work in rougher terrain than a rigid truck would be able to.
WCollins wrote:Want a 9 wrote:What advantage is there of this large ADT over a 60 ton capacity rigid frame dump truck? There maybe be some specific uses for a truck like this Bell 60 ton capacity truck, but I don't see any right off of the bat. When I talked to the guys the their booth at the Conexpo, they were telling me they designed the truck with mine development in mind, where you'd need the maneuverability and the ability to work in rougher terrain than a rigid truck would be able to. Resulting in much less time and expense grooming haul roads.
Hmmmmm . . . . that does make sense now I suppose. Thanks for the input guys. I just didn't see it at first. Now for the 100 ton ADT?
digggerr wrote:Man; I'm so glad you posted as nobody could have found this without you! Man can you ever comment on something and not be a jerk? Why do you even come on this forum?
Lee customstyrene@gmail.comhttps://www.facebook.com/customsytrene
