Joined: 10/29/2010 Posts: 1,916 Location: Maine U.S.A
[quote=Antho]To make it look a bit more realistic, take the tracks off and remove the 4 little screws that hold the track frames to the main undercarriage frame. You could put small wood blocks under it too to make it look even better. The screws are easy to see, they're on top of the main track frame between the top rollers. Around new england, we just take off the counter weight, stick/bucket.
Nothing runs like a deere with a cat on its back but the link belt ate both of them
Antho wrote:To make it look a bit more realistic, take the tracks off and remove the 4 little screws that hold the track frames to the main undercarriage frame. You could put small wood blocks under it too to make it look even better. The screws are easy to see, they're on top of the main track frame between the top rollers. Thanks Antho. I always thought it would be a pain to take the tracks off, but if it's that easy, I'll have to give it a try. Now if only CCM made it so the counter weight came off...
-Mike
CAT324DL wrote:Antho wrote:To make it look a bit more realistic, take the tracks off and remove the 4 little screws that hold the track frames to the main undercarriage frame. You could put small wood blocks under it too to make it look even better. The screws are easy to see, they're on top of the main track frame between the top rollers. Thanks Antho. I always thought it would be a pain to take the tracks off, but if it's that easy, I'll have to give it a try. Now if only CCM made it so the counter weight came off... I like it, very nice work!
-Bob
Joined: 4/14/2010 Posts: 393 Location: ste. anne manitoba canada
looking good mike!
I want that low boy, that's a sweet livery!
What wieght is the counterweight, here in Aus we'd walk it up on a Drake 4x8 or 5x8 with dolly both set at 4.0 or 4.27 meter width. Can put a ZX870 on without counterweight, scrape in just under legal wieght's.
Thanks laurent o.e.987 wrote:looking good mike! Thanks! DeWoc19 wrote:I want that low boy, that's a sweet livery! Thanks Dewoc Robert Heuston wrote:What wieght is the counterweight, here in Aus we'd walk it up on a Drake 4x8 or 5x8 with dolly both set at 4.0 or 4.27 meter width. Can put a ZX870 on without counterweight, scrape in just under legal wieght's. The counter weight weighs approximately 25,600lbs. Correct me if I'm wrong.
-Mike
Not to bring up an old threads but I read somewhere that the counter weight on the CCM 385 is removable after taking the model some what apart. Can anyone confirm this?
- Kyle
KyleS wrote:Not to bring up an old threads but I read somewhere that the counter weight on the CCM 385 is removable after taking the model some what apart. Can anyone confirm this? It can be removed. There are two screws that hold it on inside the engine compartment.
Very sweet non-slip etched pieces, the black adds to the model. I guess if you could remove the CW, then you could fabricate a plate with the CW lifting equipment and then screw it back into the model so it would look a little more natural... just a thought, but would require some fine detail work. Thanks so much for sharing!
