Mr. Scholz wrote:Hi HD41,
most of the available pdfs about the A974 tend to be field reports, but atleast I was able to find a german version of the according spec sheet:
https://www.yumpu.com/de/document/view/43185559/a-974-b-liebherrIf I can help you with any translation, feel free to ask.
I bet the undercarriage was designed and built by Liebherr in Colmar(France) at their mining shovel plant.
Cheers,
Max
Thank you Max ! This will help the scratch build expediently .
You are correct about the carrier French made in Colmar,France. Found a PDF Liebherr A974B with measurements. Carrier length 9085 mm.
Close enough for my modeling needs.
Thanks again Max.
-Unknown
