Joined: 4/17/2007 Posts: 30 Location: sioux falls, sd
I made this custom vessel and was wondering on the color. I was thinking primer gray. Most of them i have seen are primer gray or primer red/rust color what do you think? I will post pics when painted. "/> "/> "/> "/>
Looks good I like the shape you went with Jason
Joined: 2/14/2012 Posts: 156 Location: Edmonton AB, Canada
In service vessel in most cases would be silver as you are looking at the cladding over the insulation.
Insanity: doing the same thing over and over and expecting different results - Albert Einstein
Excellent work and great to see another big load being made
Rank: Newbie Groups: Member
Man how are you build stuff like that? 3D printer or what? I would like to build me a scale refinery
No 3d printer used in that, mostly plastructs add ons to the tubes. My next vessel will have prototype 3d printed landings. Here is the last on I did couple years ago. Yours has much cool shape to it Jason
Very nice.What did you use to build it?
I used pvc pipe and couplers for it to have ribs like welded pieces together. Plastruct is what I used for the ad ons they make really good quality stuff for models. I made the base plate out of styrene from scratch and the landings and railings out of scratch from styrene. I will try to get painted this weekend and post pics of it finished, hopefully before I leave for CONEXPO. thanks KC
Thanks. I didn't know that plastic pipe had same od as those couplings.I'll have to ck.learn something new.
