cat 793f norscot 55273 rear springs Options · View
graybold
Posted: Tuesday, November 28, 2017 9:15:29 AM
Rank: Newbie
hi everyone -I purchased a cat 793f from ebay -it was supposed to be new -really nice detailed model-I read that the rear suspension on this model was very stiff -my model just sits at its lowest point on the two suspension cylinders-if I lift the weight from the rear of the truck the pistons extend and the rear axle falls to the unloaded position but as soon as I release the truck to sit on a flat surface the pistons just compress -can anyone tell me -is there a fix for this and also are the springs inside the two pistons as theres no sign of any spring mechanism on my model-regards to all
rare ss
Posted: Saturday, December 02, 2017 3:48:35 AM
There should be springs inside the cylinders, my one does anyway..
Paul
Posted: Saturday, December 02, 2017 6:18:53 AM
Yeh, as Adrian says there's supposed to be a small spring system inside each cylinder but by the sounds of it your one doesn't have them or they're exceptionally weak.
I think your model is new but it's just been another QC fail from Norscot.
The underside(wheels, steering, axles) of my Norscot 795F is basically a bag of loose bolts so I bought the Diecast Masters version and what a difference.
I'm guessing you may have to try and access the cylinders and put little springs in so hopefully someone on here can give you some info on how to do that.
Smiley
