Type that into YouTube search bar. Please post links for others as I can't post links from this device. Asked last time and no one out of 583 people could bother. It's worth posting.
Thank you Quinella .
Wouldn't it be a 10X5 ?
maxcavator wrote:Wouldn't it be a 10X5 ? It is a real 10 x 10, since all 10 wheels are driven. kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Yes, but there are only 5 axles.
They call 4 axle trucks eight wheelers,or eight leggers.Even though,on this truck,there are 5 axles,the truck is still 10 wheel drive.Mean looking truck.I like it.
Maxcavator: A pickup truck that has four wheel drive is called a 4x4. That means it has 4 wheels and All 4 drive.......
Thanks for posting FiatAllisHD41. That is one cool truck!
Wish they did not have all those stupid yellow handrails on it, you could see the truck better
That’s pretty neat. But I gotta ask, why? All those tires, axels, extra moving parts, etc. for something that only hauls 150 ton? Seems kinda wasteful to me.
JTL I can agree that it does not seem like alot of payload compared to a true dedicated off highway hauler. I think its mainly for smaller operations that dont have the infastructure or loading tools to support a much larger ( read higher height) truck.
61BG wrote:JTL I can agree that it does not seem like alot of payload compared to a true dedicated off highway hauler. I think its mainly for smaller operations that dont have the infastructure or loading tools to support a much larger ( read higher height) truck. It also probably does a heck of a lot more,than a bigger payload dumptruck,that can only be used for earthmoving.It can undoubtedly move other trailers.Where a conventional tractor cannot go.
Actually it should be a 10X16, 10 drive wheels and 16 total wheels.
Joined: 9/4/2005 Posts: 3,250 Location: Le Muy - Var - France
Dain555,
Sorry, but I don't agree with you. If the tractor has 5 powered(driven) axles, of which 2 are steered, then it should be called a 10x10/4, and I think that's the way of defining it around the world.
Regards. Guy
That's a sweet rig, I know they use them a lot in northern Labrador for hauling iron ore with side dump b-trains. As far as what to call it I'd say it's a tandem or twin steering tridem tractor unit with I'm guessing planetary drive hubs for all wheel drive. I've seen this axle set up less the planetary hubs before with a local precast company that hauls fairly large septic tanks and precast wall blocks with it, same with a couple foundation forming companies.
- Tyler
On anther note, this looks awesome! https://youtu.be/C5GzK2wUudMIt's a collaboration between dramis and simard suspension systems, it's supposedly able to haul 55 metric tons. With the new SPIF regulations in Ontario I wouldn't be suprised to see on-road versions of this truck to haul 25 tons.
- Tyler
Joined: 1/20/2004 Posts: 125 Location: Alberta Canada
Dramis d150t 10×10 kenworth C500 haul truck for mining
Dramis International, Simard Suspensions Off Road department, presents its new mining truck, the D150T, imagined, designed, manufactured and assembled by our teams.
The Dramis D150T meets point by point the specifications imposed by the driving conditions of the truck:
The truck must haul 150 metric tons of Gold ore over a distance of 144 kms back and forth, on a road made of crushed rocks with 8% slopes and also has to cruise at 50 km/h loaded.
The D150T operates in a mine located in the Kivalliq region of Nunavut, Canada’s Great North, where temperatures can drop below 45 degrees Celsius.
Consequently, each element has been designed or selected to provide the best performance, maximizing reliability and security.
DRAMIS D150T specifications : ◾Kenworth C500 chassis ◾X15 Engine : 605 Hp, 2050 Lb-Ft ◾Alisson 6620A automatic transmission ◾Namco auxilary transmission ◾AMS50THD 50 000 lbs front twin steer suspension ◾DTS 135 000 lbs rear hydraulic suspension ◾Rear Planetary axles ◾Dump Bodies : 2 x 40m3
