Joined: 2/27/2006 Posts: 77 Location: HENDERSON NEVADA
I found this resin kit on Ebay. It is a copy of 1/50 scale Conrad IH 5600i model and I think the caster used a cement mixer as water tanks are included for the side of the frame. The frame is straight and the tires are resin and seem to be true round. I am not sure how I will build it , a tractor maybe.
You should get royalties from this as it was your truck.Looks good .Does it come with glass for the cab?
There is clear plastic, have to drill rear axles through and drill cab for exhaust stack.
Kind of a cool novelty but don't see how you will like it when you are used to the much nicer DieCast.
Interesting find Roy, have not seen this one before. I wonder if they would consider selling any of the parts separately, I could always use an extra set of those mirrors for my Conrad trucks.
Only 1 mirror and does not look that good, I have a set of Conrad mirrors to use. I asked the seller if he had anymore like this or if he knew where to get more and he advised that he did not. The kit came in a big baggie no ther inforamtion but I will keep looking. The rear axles appear to be case into the frame, the front axle is very simuliar to the ones Conrad uses today.
Is that not an copy of Conrad property? Would this not be a counterfeit model?
I was the license holder Conrad was the manufacture my call but for a one of not worth the hassle
That is so strange Roy. You got to wonder why someone would go to the trouble of casting that when they could buy a diecast metal one for less than $100.00, full assembled and painted. How much did you pay? Craig
RFSALES wrote:I was the license holder Conrad was the manufacture my call but for a one of not worth the hassle In that case that would work
Craig: You have been in this hobby for along time, does any of ot make sense ? I would guess the caster did it because he could !
