Joined: 9/4/2005 Posts: 3,249 Location: Le Muy - Var - France
Steve, The reefer unit on the truck was homemade - based on pictures from that period - while the one on the Blumhardt trailer is a Modeltruck Onderdelen white metal kit (see below): It is an accurate 1/50 model of Thermoking vintage units which were fitted on most reefer trailers and semi-trailers during the period 50s/70s. Link to Modetruck Onderdelen parts pages: http://www.modeltruckparts.nl/english/Index-en.htmI hope it helps. Guy
Guy thanks for the information both the kit and the scratch built units fit the bill. Steve
We're still in Germany but during a much darker period with 4 Solido(*) models representing Wehrmacht armored vehicles used on the Russian front in the period 1943/44: From left to right: - MAN Pz.Kpfw.V/Ausf.G main battle tank (700hp, weight: 44.8 tonnes, one 75mm canon and two 7.92mm machine-guns), - Krupp Pz.Kpfw.IV/Ausf.F2 battle tank (300hp, weight: 25 tonnes, one 75mm canon and two 7.92mm machine-guns) - Büssing-NAG/Deutsche Werke GS 8x8/8 armored radio reconnaissance vehicle (155hp, weight: 8.5 tonnes, one 20mm canon and one 7.92mm machine-gun), - Hanomag H Kl 6p armored personnel carrier half-track (100hp, weight: 7.81 tonnes, two 7.92mm machine-guns). Note (*): these 4 models were bought on e... a few years ago and are all stamped Solido on the underside. But I couldn't find any trace of that sort of camouflage in the Solido range: are these Code 3 models? Or small series made by companies like Verem? Hachette? Gaso.line. Other? As I am not a specialist in military modeling, any additional information is welcome. To be continued. Guy
Both Büssing-NAG/Deutsche Werke (Sd.Kfz 232/FU) and Hanomag (Sd.Kfz 251/1) vehicles: To be continued. Guy
Both battle tanks Generation IV (25 tonnes) and V (44.8 tonnes): Regards. Guy
Heavy haulage set built by Jean-Jacques: The Scheuerle dolly pushed by the DAF NTT Tractor is a Zon Models kit. To be continued. Guy
A Spada heavy transport in the Nice area during the 60s/70s, which was at the origin of Jean-Jacques' set. Hardly visible at rear, there is a second Berliet truck pushing a Rogers ex-tank transporter which went in reverse mode all the way: not an easy task for the driver, for sure!!! Luckily enough, roads were not that busy at that time and average speed of the heavy haulage set was pretty low, giving the rear driver enough time to react and realign the rear drawbar trailer, if required: Regards. Guy
Richelmi (Monaco) bringing equipment to one of their construction sites. The drawbar trailer at rear was built from a Bemo Models kit: Regards. Guy
Guy great pictures of models and the real thing along with information provided. Thanks Steve
Whatever those tanks turn out to be,they look much better with black tracks.
In Great Britain during the 50s, 2 Bedford trucks Type O, designed by the British company before WW2: - To the left: Bedford OLAC 4x2/2 high volume box truck (72hp, GVW: 6.05 tonnes, GCW: ?? tonnes): modified Corgi model, - To the right: Bedford OLB 4x2/2 flatbed truck (84hp, GVW: 7.62 tonnes, GCW: ?? tonnes): modified Corgi model fitted with a homemade bed. To be continued. Guy
The Bedford OLB carrying a Jennings & Son livestock transport removable box (modified Corgi element) and an unknown brand removals early container (ex low slung box originally fitted on the Bedford): Regards. Guy
In Great Britain again, a "Mickey Mouse" cabbed Foden tipper: Foden S21 FG 6/24 8x4/4 tipper (180hp, GVW: 22/24 tonnes, GCW: 32 tonnes) loaded with 17 tonnes of stones and gravel: Corgi model Regards. Guy
I had a Matchbox Foden as a kid. Always impressed with that highly stylized cab but pity the driver having to climb up into it!
Rob
Guy the Bedford and the Foden trucks are in very nice condition how old would those be. Steve
Steve,
Bedford O and Foden S21 trucks were produced in UK, respectively in the 50s and in the 60s. Corgi Classics models in a 1/50 scale date back from 1990s/early 2000s. As far as I remember, early Bedford trucks were still fitted with "button-type" wheels: they have all been changed to better-looking Lion Toys spares.
Guy thanks for the information those two trucks look great.
Guy: I collected Dinky Toys. All I have left is a MIB Austin Black Taxi. I also love Brittain Toys. Craig
Craig,
I used to play, like every kid at that time, with Dinky Toys and didn't care at all for their different scales. I still have a few of these, generally 1/55 or even smaller, but all are in play-worn condition. A few years ago, I realized that quite a lot of their models produced before (or around) 60s were in an accurate 1/48 scale: that's why I started looking at them again on e... or in swapmeets.
As far as I know, Britains models are in a slightly larger scale, so I don't have any.
Regards. Guy
- MAN TGX 33-580 FVLS 6x4/2 tractor (580hp, GVW: 25/26 tonnes, GCW: 44/?? tonnes): modified Conrad model, - Nooteboom MCOS 48-03(EB) 3-axle low bed semi-trailer (GVW: 45/48 tonnes, payload: 32.3/35.3 tonnes): Conrad model, - Ammann AV 110X articulated road roller (99hp, weight: 10.4/11.2 tonnes): Ros model, - Caterpillar AP 655D tracked finisher (175hp, weight: 19.17 tonnes, working width: 2.55 to 5 metres): Norscot model Regards. Guy
