3D printed load test weights and a equalizer bar , and Manitowoc 4100 parts Options · View
eef7260
Posted: Friday, May 10, 2019 12:36:20 PM
Did some 3D design and printing again ,
This time it's a set of load test weights and a equalizer bar.
Made 3 weights sets , 20 Ton , 50 Ton and a 100 Ton.
Can be used as a single weight set or double in combination with the equalizer bar.
They are printed as one solid piece but have a hollow chamber on the bottom side.
This can be filled with what ever you want for the weight , piece of metal , lead , concrete etc.
Dimensions are 20Ton = 36 X 58 MM , 50Ton = 66 X 80 MM and 100Ton = 56 X 100 MM.
Equalizer bar = 80 X 43 MM.
Al this can be ordered by shapeways again : Shapeways shop
IMG_20190510_150035 by eef 7260, on Flickr
IMG_20190510_145856 by eef 7260, on Flickr
IMG_20190510_150145 by eef 7260, on Flickr
IMG_20190510_150308 by eef 7260, on Flickr
IMG_20190510_150113 by eef 7260, on Flickr
And some Manitowoc parts , a pendant rope spreader , can be found here : Shapeways shop
IMG_20190417_113742 by eef 7260, on Flickr
Pendant spreader 3 by eef 7260, on Flickr
And a set of Manitowoc pendant connectors can be found here : Shapeways shop
pendants by eef 7260, on Flickr
Assembly1 by eef 7260, on Flickr
***My website***Flickr American cranes group***3D printed crane parts***
