Euclid R-62 dump truck in 1/24 Options · View
Mr. Scholz
Posted: Monday, March 09, 2020 12:59:30 PM
Kerst, the first car of my father was a BMW Dixi and this car had conical shaped leather clutches, too. So leather is a real good choice for clutch surfaces on a scale model power shift. Thanks also for sharing the drawings of the Clark power shift. Wonderful craftmanship!
Cheers,
Max
kerst
Posted: Sunday, March 15, 2020 9:51:36 PM
Thanks for the compliments!
I am in self-imposed isolation in my workshop, so lots of time to work on the Clark transmission.
Here a few pictures of progress. i worked on the clutch assemblies today, still not finished though. Lots of little parts.
I will connect the input shaft (top middle ) with a flexible coupling to the motor with reduction case.
The output shaft (bottom middle gets a bolt-on divider to go to both rear axles.
Kerst
RobS
Posted: Monday, March 16, 2020 9:12:37 AM
Incredible work Kerst! An interesting Clark note: They were located not far from me in Buchanan, Michigan. They had a testing facility that lives to this day as Clark Testing. I was there just the other day on a work project. Some very large test equipment including many dynamometers for testing these very gear boxes. So if you need to have this one tested, let me know and I'll hook you up!
Keep the pics coming, this is a fascinating build!
Rob
Exkvate3140
Posted: Monday, March 16, 2020 10:28:41 AM
Rob they will probably hire Kerst if he goes in there with his project. We need him here.
Amazing work.
Steve
kerst
Posted: Thursday, April 02, 2020 5:07:44 PM
Due to the crisis I have lots of time for the gearbox. It slowly comes together. I finalized the input and output sides. I hadn't thought about these at all when I started building the gearbox, so some adjustments needed to be made.
I also had to adapt the whole assembly so it would fit in the truck!
Next are the levers to control the shifting. See how that works out!!
Kerst
kerst
Posted: Saturday, April 11, 2020 5:56:30 PM
Today I did my first test run and I took a short video.
It is a 4-speed power-shift and the first and second speed work nicely. The third works OK, but the fourth speed seems to take all the power. Too much friction or too much speed.
I will consider a bigger reduction between motor and gearbox.
Here is the video: https://youtu.be/4hA-Vlfxj6M
Here are two pictures of the whole assembly:
Kerst
Exkvate3140
Posted: Sunday, April 12, 2020 12:45:36 AM
Kerst that is just incredible.
Steve
kerst
Posted: Tuesday, May 05, 2020 8:15:54 AM
I added another motor. It might be overkill and it is easy to take it away. I can also easily change the reduction between motors and gearbox. Now it is 1:4. I tried it with the battery with a much steadier output than the transformer. That is good news!
I bought some micro servos to control the transmission. There is not a lot of space, so one of them sits outside the cab.
Here is the motor unit and the transmission:
Here are both units installed in the truck:
This is the truck with only the transmission:
The servos:
Kerst
JohnGalt
Posted: Tuesday, May 05, 2020 11:48:06 AM
Kerst, your machinist skills are amazing. I always look forward to seeing your updates on your projects. Great work.
kerst
Posted: Tuesday, May 05, 2020 5:01:21 PM
Campmb
Posted: Tuesday, May 05, 2020 7:12:15 PM
Truly an epic build Kerst. You’re machining skills are unreal! I grew up in Euclid where they were built, so it brings back memories. Mike
Quinella
Posted: Tuesday, May 05, 2020 7:26:49 PM
Kerst: Where did you obtain your skills? This is so over the top for me. What is your profession now? Great build of course. CAW
JoeE
Posted: Tuesday, May 05, 2020 7:37:37 PM
Absolutely awesome kerst!
Please keep posting updates.
Exkvate3140
Posted: Tuesday, May 05, 2020 10:31:32 PM
Kerst, your truck and your craftsmanship impress with every post, it is just incredible.
Steve
kerst
Posted: Monday, May 25, 2020 12:22:26 PM
I never thought I would get (into) electronics, but so far it seems to work out.
In the past weeks i worked on all the electric connections and finding space for the electronics, etc. Although the Euc has a huge hood, I had to try various setups in order to find the right setup that fits inside the hood and cab without being too visible.
I bought an 8 channel system. One channel for the speed control, 2 channels for the 4-speed transmission, one for the on-off-on switch for the tipping motor, one for the on-off-on switch for the driving motor and one for the steering servo.
Kerst
Exkvate3140
Posted: Monday, May 25, 2020 12:47:37 PM
Kerst you can always go to 1/16 scale, we can wait with your knowledge and skill we are probably looking at a day or two. That’s amazing, had no clue that there was that much involved in RC never mind the cost. Keep up the great work.
Steve
SDBOB
Posted: Monday, May 25, 2020 8:17:53 PM
Yes very detailed ,nice work.
kerst
Posted: Friday, June 26, 2020 5:19:08 PM
I found the right paint for the Euc. It looks decent, the color is very nice but needs a second coat and I didn't buy enough!! That means waiting.
Kerst
JohnGalt
Posted: Friday, June 26, 2020 6:22:02 PM
WOW!!!
Quinella
Posted: Friday, June 26, 2020 6:31:42 PM
I cannot wait to see this beast. Looks terrific so far.
