Joined: 9/4/2005 Posts: 3,249 Location: Le Muy - Var - France
DAF FT 75-300 ATi 4x2/2 tractor (Tekno model) and Hobur 3-axle tank semi-trailer (modified Tekno model) Regards. Guy
Volvo F89 6x2/2 tractor and Ackermann-Fruehauf 2-axle container carrier semi-trailer (modified Tekno models) carrying Americontainer and Fruehauf-France 20ft maritime containers (Tekno elements) Regards. Guy
Various Schwing concrete pumps: - left: DAF FAT 2205 DU 6x4/2 truck fitted with a Liebherr HTM 704 concrete mixing drum (Lion Car model and Conrad element being modified) towing a 1-axle trailer with a modified Schwing BPL 600 HD concrete pump (modification in progress with NZG elements + bits and pieces from the surplus box), - right: Mercedes-Benz 1622 4x2/2 truck equipped with a Schwing BPL 600HD/KVM 23 concrete pump and distribution boom assembly (NZG model). To be continued. Guy
We have a say in France "Nothing gets lost, everything can be upgraded and re-used". The Schwing pumping trailer made from parts coming from a damaged NZG model: To be continued. Guy
The original model produced by NZG (here in limited edition with logos of the French import company for Schwing pumping/distribution equipment): Regards. Guy
GuyM wrote:[...]Volvo F89 6x2/2 tractor and Ackermann-Fruehauf 2-axle container carrier semi-trailer (modified Tekno models) carrying Americontainer and Fruehauf-France 20ft maritime containers (Tekno elements)[...] Early 1980s, another containers transport made from old Tekno models: Scania LB141 6x2/2 tractor (modified Tekno model) and Trailor 2-axle flatbed semi-trailer (Tekno model being modified) carrying 2x20ft Sea Box Inc. and SNAV maritime containers (Tekno elements) Regards. Guy
MAN TGS-M 33-510 6x4/2 truck fitted with a Meiller 3-side tipping body and its Schwarzmüller Tü 40-100 2+2-axle drawbar lowbed trailer (Conrad models) used in the delivery of a 28 tonnes Ammann ART 280 1+1-line ballasted wheeled roller (USK model) Regards. Guy
Work in progress on 2 transport/delivery combinations: - left: DAF FT 2505 DHU 4x2/2 tractor (Lion Car model being modified) and Stetter AM8 2-axle concrete mixing semi-trailer (assembly of Joal and Conrad elements in progress), - right: Mercedes-Benz Actros 1840LS 4x2/2 tractor (modified Joal model) and DAF 3-axle covered sheeted semi-trailer (Lion Car model being modified) equipped with a Kooi-aap Z2-3-203 "piggy-back" 3-wheeler forklift (Siku model being modified). To be continued. Guy
- left: SAVIEM SM 300 4x2/2 tractor (modified Solido model) and Castera 2-axle lowbed semi-trailer (modified Corgi Toys model) carrying a John Deere 4425 4x2/2 combine harvester (modified Ertl model), - right: SAVIEM SM 280TU 4x2/2 tractor (modified Solido model) with a Trailor "train double" (French conventional B-Train), made of 2 Trailor 1-axle sheeted dropside semi-trailers (modified Tekno models, to be painted) and of 1 Trailor 1-axle towed dolly (modified Matchbox element, to be painted). To be continued. Guy
The 1970s French agricultural equipment transport: To be continued. Guy
The "train double" (conventional B-Train*) developed by Trailor in the 1970s in response to an evolution of French road regulations, allowing for 2 short semi-trailers to be towed by a 2-axle tractor: Note *: the French B-Train, which appeared a little bit later, has a fifth wheel fitted to the sliding part of the front semi-trailer chassis, improving the behavior of the combination in reverse conditions. Regards. Guy
MAN 19.314 FLS 4x2/2 tractor and Van Eck 2-axle low bed box semi-trailer (modified Conrad models) Regards. Guy
Renault Trucks Magnum 480-19dXi 4x2/2 tractor (modified Joal model) + Metaco SD 334 3-axle curtainside box semi-trailer (Joal model being modified) Regards. Guy
In the 70s/80s, Allis-Chalmers plant equipment at work in the USA: Allis-Chalmers HD21 crawler tractor and Allis-Chalmers C108 1+1-axle towed scraper (First Gear models) Regards. Guy
Another American combination some years later: Caterpillar Challenger 65 rubber-tracked tractor (modified Joal model) and Miskin D19 1-line towed scraper (modified First Gear model) Regards. Guy
Back to Continental Europe, late 80s: - front vehicle: Ford Cargo 1517C 4x2/2 truck fitted with a covered dropside body (modified NZG model), - at rear: Mercedes-Benz 1114 4x2/2 truck equipped with a reefer body (NZG model). To be continued. Guy
