Joined: 9/4/2005 Posts: 3,432 Location: Le Muy - Var - France
The SOMUA tank was also surpassed by German tanks, because of its numerous mechanical breakdowns or fuel shortages (as French Army Logistical Services were unable to follow the pace of German Panzerdivisionen), in spite of some successes, which only postponed the end of the battle:    The Somua tank in Wikipedia: https://en.wikipedia.org/wiki/SOMUA_S35Regards. Guy
Joined: 6/18/2003 Posts: 2,216 Location: Charlotte, North Carolina
Not much of a gun there!!! Looks cool though. CAW
THE GUN LOOKS LIKE YOU
George Hiram wrote:THE GUN LOOKS LIKE YOU Well well. Look what the cat drug in! You probably fought in that war. CAW
SOMEONE IS TELLING STORYS ON ME AGAIN
In Holland, transfer between 2 gravel extraction sites:   Scania-Vabis LT 110 Super 6x4/2 tractor with dropside body (modified(*) NZG model) loaded with an unknown brand dragline bucket for crawler crane (NZG element) and towing a Scheuerle T 5041 L 2+2-line semi-trailer with extra-low bed (NZG model), carrying a 54.7 tonnes Weserhütte W180 lattice dragline (modified(*) NZG model) and a lattice boom extension (NZG element),   Note (*): normally towing a similar 3+3-line Scheuerle trailer, the Scania-Vabis tractor had its guiding poles glued (both broken as very fragile); the Weserhütte crane had its pulley lifting frame lowered for the transfer (by removing rear rivets), its right rear access ladder repaired (fragile) and its right access path glued again. Regards. Guy
Guy: that is an absolute killer looking rig! Craig
Craig,
Many thanks for your positive comments.
Guy
