Joined: 6/18/2003 Posts: 2,235 Location: Charlotte, North Carolina
Guy: You are right about avoiding license fees. But these are actually pretty good quality for the money. You can buy one sometimes as low as $12.00 give or take. The tank trailer is cool. And the wheels ae super. I probably have purchased three dozen of thses oveer the years. Craig
Joined: 9/4/2005 Posts: 3,473 Location: Le Muy - Var - France
Craig, Many thanks for the info on the Citgo model: they are pretty rare (and more costly) on that side of the pond. Another Mack (fully licensed):  Mack Anthem 64T 6X4/2 tractor and Trailmobile ?????45 2-axle box semi-trailer (First Gear models),    Regards. Guy
 - left: Minitrucks cab kit on a Conrad tipper chassis, - right: Minitrucks kit. Both models are built by Jean-Jacques. To be continued. Guy
The Magirus-Deutz tipper:    To be continued. Guy
The Hanomag-Henschel tipper:    Regards. Guy
Guy: The Mack Vision trucks are terrific. I used to have maybe a dozen. The quality is great. The various logos were great. I think they are 1:54 scale. As I remember, First Gear made Freightliner versions too. thanks,Craig
Craig,
Sorry to seem to contradict you but the Vision box semi-trailer could just be a 96'' wide 45' long Trailmobile trailer in a 1/50 scale (2.44 meters wide, 13.72 meters long), while First Gear also produce unknown brand 102'' (2.59m) wide 53' (15.6m) long units in the same scale. I agree with you, the Vision box trailer looks smaller than its counterpart in that case.
I hope it helps. Guy
Guy: Google First Gear 1/54 Mack Vision trucks and you will see some of the various trucks they made. Craig
Craig, You are right about the Mack First Gear scale: I recently found these 2 pictures on e...:   I hope it helps. Guy
Soil removal by Jean-Jacques. The Magirus-Deutz tipper (Minitrucks cab on Conrad tipping chassis) being loaded alongside a Berliet tractor and its tipping semi-trailer (Minitrucks kits). The cable excavator is a 1/50 NZG Menck & Hambrock model:     Regards. Guy
Willeme logging truck (Minitrucks kits), by Jean-Jacques:     Regards. Guy
GuyM wrote:The same crane in its roadable version. Shield Bantam T35 lattice crane with grab on a White WC22 Mustang 6x4/2 truck, roughly changed into a crane carrier at minimum cost (SpecCast model):  Regards. Guy Guy, est-ce une version du commerce ou une version faite maison? Merci de ta réponse. www.ec1000.net
Pascal,
Ce modèle SpecCast est intégralement du commerce, sans modification de ma part.
This SpecCast model came direct from the shop, I didn't change anything to it.
Regards. Guy
Other Willeme transports:   The Willeme truck, together with a Berliet unit (Minitrucks kit):  The Berliet truck, converted into a logging combination:  Regards. Guy
  - Left: Renault R 2087 4x4/2 light truck, fitted with a Guinard tank/fire pump (Solido model), - right: Renault R2087 4x4/2 light truck with a sheeted dropside body (Verem model to be modified*)), towing a modified Ben Hur Mfg G 527 1-axle tank trailer (Verem model). Note (*): transmissions/axles to be modified. To be continued. Guy
In Europe, beginning of the nineties, sleeping compartment over the cab trucks began to appear, aimed at optimizing the overall length of heavy vehicles. Late nineties, a modification in European rules related to useful boxes lengths only (cabs excluded) led to the extinction of such practices:  DAF FAS95-360 Ati 6x2/4 truck fitted with a bunk-over-the-cab device and a large volume Kögel box (modified Tekno model(*)) and its matching Kögel 2-axle close-coupling large volume box trailer (Tekno model),    Note (*): one of the Kögel box door (fragile) on the truck was glued in closed position. Regards Guy
Multiple winner of the "24h du Mans" endurance car race, H. Pescarolo created his own car race team, Pescarolo Sport, which will be finally bought-out in July 2010, following some financial problems:   Scania R620 4x2/2 tractor and Krone ???? 3-axle semi-trailer upgraded into a race assistance box unit by the French truck body builder Toutenkamion (?) (modified(*) Universal Hobbies models),   Note (*): tractor's fifth wheel and semi-trailer's king pin were modified to accept WSI models. Link to the Wikipedia article dedicated to H. Pescarolo (in French, sorry): https://fr.wikipedia.org/wiki/Henri_Pescarolo . Regards. Guy
Guest,
Westernstar10 |
