Joined: 9/4/2005 Posts: 3,497 Location: Le Muy - Var - France
The Siku model is advertised in a 1/55 scale, which is the scale of the towing car. Boat and trailer information listed at the back of the box seems to advocate a 1/52 scale (except for the boat width 1/55 and hectic height scales of respectively 1/75 and 1/96). The Audi car was replaced by a 1/50 van with real dimensions of both boat and trailer searched and found, to simply add a new 1/50 scale combination:    Renault Trafic 4x2/2 van (modified(*) Solido model) and Harbeck Fahrzeugbau BT 3500 MALM6-Confort 2-axle boat trailer (modified(*) Siku model), loaded with a Performance Marine 807 in-board 2-engine racing boat (Siku model),   Notes (*): the towing eye on the Siku trailer was replaced by a camper-type towing device with a corresponding hook added at rear of the Solido van. Regards. Guy
Joined: 6/18/2003 Posts: 2,243 Location: Charlotte, North Carolina
Yes Guy, the van looks more realistic in scale and likely to pull the boat. Boat looks fast, Hope it has seat belts! Craig
Even when the Siku combination is mainly made of 1/50 models, the recovered car is (badly) reproduced in a 1/55 scale:  With the addition of a Conrad model, you can have, at low cost, a coherent combination in a 1/50 scale:    Mercedes-Benz 307 4x2/2 van (modified(*) Conrad modiel) and Böckmann AT 4019/27 2-axle car transporter trailer fitted with a tilting bed (modified(*) Siku model) carrying a Volkswagen 2T1-1.2 MT 4x2/2 van (Siku model),  Notes (*): the towing eye on the Siku trailer was replaced by a camper-type towing device with a corresponding hook added at rear of the Conrad van. Regards. Guy
Several WW2 American vehicles end-up in the French ex-military surplus enabling... French firemen to get equipped of cross-country vehicles at low cost:   - left: all-terrain light truck Dodge WC53 Carryall 4x4/2 (modified(*) Solido model), - right: Dodge WC53 Carryall (Verem model). Note (*): a battle tank antenna was added to the Solido model. To be continued. Guy
In USA these days:   Volvo USA VNL 680-500 6X4/2 tractor and Great Dane Champion 53 2-axle box semi-trailer (First Gear models),   Regards. Guy
In the USA still, with a STAA Double (Surface Transportation Assistance Act, double semi-trailer), which is the first LCV (Longer Combination Vehicle) to be accepted on the entire country road network:    Peterbilt 330 Series 4x2/2 tractor (modified(*) Norscot model) and Wabash DuraPlate 28 1-axle box semi-trailer (modified(*) Diecast Masters model), plus Wabash ???? 1-axle dolly with 5th wheel (Diecast Masters model) and Wabash DuraPlate 28 1-axle box semi-trailer (modified(*) Diecast Masters model),  Notes (*): the Norscot truck had its IMT servicing body removed and a white metal 5th wheel and access platform added. The front semi-trailer received a king pin compatible with the tractor's 5th wheel . Both semi-trailers had landing legs added (missing). Modifications are still to receive a new coat of paint. Link to the Wikipedia topic related to STAA Doubles: https://en.wikipedia.org/wiki/STAA_doublesRegards. Guy
 Mack MD7 4x2/2 stake bed truck (Conrad model) loaded with 5.76T of beechwood planks (homemade load),    Regards. Guy
The re-issue by Norev of CIJ models was a good opportunity to increase my collection at reduced cost:   From left to right: - Citroën 47 DI C2 4x2/2 tractor (modified(*) Corgi model) and Heil S2A 1-axle tank semi-trailer (modified(*) CIJ-Norev modiel), - SOMUA JL 19CT 4x2/2 tractor (CIJ-Norev model being modified(*)) and Fruehauf 1-axle tank semi-trailer (modified(*) Corgi model). Notes (*): - the Corgi tractor had its 5th wheel modified to accept my semi-trailers, - the CIJ-Norev semi-trailer received a new king pin suitable for tractor's 5th wheel, Corgi wheels, a narrower landing poles system and a discharge cabinet on the right side. To be repainted, - the CIJ-Norev tractor saw its proprietary 5th wheel disappeared, replaced by a WSI one. Lion Car wheels complete the model. Are still to be made the cab interior and a new coat of paint, - the Corgi semi-trailer received Lion Car wheels, rollers under its landing legs and a WSI-type king pin. To be continued. Guy
The Citroën/Heil Shell outfit;    To be continued. Guy
The 2nd Shell tanker:    Regards. Guy
In Northern Europe, The Scania offer in terms of mining dumper:   Scania G 500 B-HZ Buffalo 8x4/4 truck with KH Kipper tipping body* (Tekno model),   Note (*): this vehicle is limited to 32 tonnes on European roads (as for any 8x4 truck) but can handle up to 58 tonnes GVW on closed sites (quarries, mines...). Regards. Guy
Weitz crane built by Jean-Jacques using a Minitrucks kit:     Regards. Guy
A Berliet TLC tractor, Minicirque kit built by Jean-Jacques:    Regards. Guy
