would anyone have pics of the lr 1280 they would be willing to post, im thinking this may be my next crane....just want a few different pics of it....any pics would really help......thanks
dewoc...any idea on how much boom it comes with?......approximatly how tall you think it is?
i dont recall if he has extra boom in it or not, but i think stock out of the box its about 4 ft tall
thanks sir......will keep an eye out for one.....i think its gonna be my next one
alright one more question for ya......how hard is the riggin for this crane?.......thats to a normal human....not a rigging machine like yourself!
i dont think reeving is that hard, i just re did the gantry to my 18000 about an hour ago cause it was messed up when it came out of the box and i was to lazy to do it then
its all about patience, it shouldnt be to hard to get done, it doesnt cross any where so its a straight up down left to right reeve, just try and have the reeving distance in the shortest distance possible so there is less chance of the cable jumping off the pulley
ohhh yea...one more.............whats a luffer and a gantry....im pretty sure i know what the jib is
you see in this pic, the yellow part the goes on an angle upwards at the bottom of the crane, thats a gantry also called an A Frame.... a luffer is the part on the top of the boom that is slightly angles, there is a difference between a luffing jib and a fixed jib luffing jib luffs ( has the ability to change the angle of the jib) fixed jib is fixed in a specific angle and cant be moved like a luffer can
Joined: 3/20/2007 Posts: 1,044 Location: Lexington, Kentucky
Is a luffing jib also a fly jib??? Thanks
treeman
, Moderator
Here is a link to a joint venture project between forum friend bluebarn and myself on the how to rig a crane. We did a Sennebogen 5500 Starlifter, which other than size is basically the same rigging as the LR1280. Maybe this will give you the general idea of what is required, Its not that hard once you get the hang of it. rigging a crawler
yeah, its called a luffing fly jib,
, Moderator
I always thought that the fly jib was the same as the fixed jib. That is the term I have heard used when the jib is used with a hydraulic truck crane. Any operators confirm??
Joined: 12/14/2006 Posts: 811 Location: Buffalo, New York
Lr 1280 was my first crane and definitely one of the best cranes. It was fairly easy to rig and assemble. I have one set of boom extensions on it right now. Stock   + 1 set of extensions compared to my 16000
fly jib supports itself with no pendants ,fixed jib has strut and pendants. all the manufacturers have different lingo.
What do you get with the boom extension kit? How much? Where?
here are some  You can see the midfall attachment I built for it  Custom fixed jib I make for the 1280  next to the 1750  next to the water tower I built  Great crane you can set it up in many different configurations There is more pics on my website of it in my dio Jason NIkl Scale Models
Why the different color between the 1280 and 1750?
