Joined: 9/3/2005 Posts: 433 Location: One of the smallest countries with most big cranes
Dismantling of a towercrane :d/  I had rather poor reach up this high  www.emielschoonen.nlGreed isn't going anywhere. They should put that up on a billboard across Times Square!
Emiel, I hope you have more pictures of this crane, close ups. I saw a video of this crane on Youtube moving on a construction site. Thanks for posting your pics.
As always, a pleasure to see your photos on the Forum...
Joined: 8/24/2006 Posts: 2,185 Location: Grapevine, Tx
That baby has some boom in her now!! Some close ups of the carrier and upper works would be great. Thanks for the pics!
Jeff
Man that is a cool looking crane. thanks for the additional pics Jason NIkl Scale Models
It always amazes me that they can find enough room in an urban area like that to assemble and disassemble a crane boom of that size. Thats got to be over 500 feet of boom / jib. Great pics.
great pics , not bad enough that there's a limitation on room ,but it also looks like the out board outriggers are sitting on a ramp or entrance to a tunnel nobody had a rubber measuring tape on that job
That is quite amazing! What a great diorama it would make  Paul R
Would I be correct in assuming the (3) sheaves on top are for (3) different lines coming form three different winches - assuming rather a massive load for a jib? So with (1) winch, the single line will only be reeved to the center set of lower sheaves? With (2) lines, they would be placed on the outside (upper) sheaves and reeved into the outside (lower) set of sheaves?
Joined: 4/27/2006 Posts: 2,826 Location: Carmarthen, Wales, UK
tsham wrote:It always amazes me that they can find enough room in an urban area like that to assemble and disassemble a crane boom of that size. Thats got to be over 500 feet of boom / jib. Great pics. It´s more than 650 feet (95m main boom + 105m extension = 200m). Probably the highest mobile crane ever. Jan
ulf wrote: Would I be correct in assuming the (3) sheaves on top are for (3) different lines coming form three different winches - assuming rather a massive load for a jib? So with (1) winch, the single line will only be reeved to the center set of lower sheaves? With (2) lines, they would be placed on the outside (upper) sheaves and reeved into the outside (lower) set of sheaves?
This jib-head is also used for long mainboom lengths, it's just called "light-boomhead". You are correct regarding 2 lines going into 1 hookblock, the third sheave is used for the runner. I know I got a picture of it somewhere....  Found it, runner is attached to the boomhead and 1 line goes over it to the hookblock   www.emielschoonen.nlGreed isn't going anywhere. They should put that up on a billboard across Times Square!
Great photos as always!
Thanks for sharing them.......as always!
Chris
Thanks for the info, Emiel!
