, Moderator
Okay folks its time to post Team USA results for rigging the PTC. Sorry it took Team USA so long to get it done, but hey, that’s life in the USA! Today was the 17th anniversary of my 29th birthday, so I took it off to play with my PTC. So this post will be a little multipart as I am going to post my reeving time, post a few how to’s and a small review of the PTC. A full review of the PTC will be up on my website later this evening, with 82 pictures. Part one: Reeving time totals: 100 minutes for the main boom and the luffer, and 151 minutes for the main hook and small hook. However I need to give myself a 8 minute deduct for the phone call from mom, and I need to deduct another 6 minutes for the phone call from the boss man. So Team USA time is 237 minutes. Paul???? Time to post and remember I am a moderator and can edit your post!!! (I would never do that) Part two: Here are some pictures of my hook reeving that happened today. The main hook that comes with the PTC has keepers on the hook to prevent rigging from coming off. And unfortunately the manufacturer made these permanent not spring clips that work. So in my infinite wisdom I tried to drill out the pin to make it work. This unfortunately lead to my breaking the part off. So a quick dab of epoxy and it went back together in its non-functional state. And here are a couple of the pictures of my set up. The book shows laying the hook block lose on its side-that is nuts! Holding things tight is a better idea! Part three:The PTC I am really liking. Yes it was pricey, but a heck of a detailed model. I think having WSI as their masters made TWH do a better job than on some previous offerings. The disappointments are: You cannot break down for transport mode-impossible The pre rigging of the counter weight connections is, ah, difficult to deal with at best-all four block and tackles on a common drum-no possible way to loosen them or tighten without them jumping when undoing the tape. I had to re reeve all four blocks - 3 hours worth The pre measured pennant lines to the main boom-one tight the other lax and swinging in the breeze. The only way to tension is to lay the boom out at about a 35 degree angle-other than that no means to adjust. All of the backmast stays did not have the right size hole in them to accept the screw provided and required drilling all 8 out to the right size-not the end of the world, but still…. The good points: It goes together pretty easily Everything fits and no defects in the parts other than the back mast stays It spins on the track super easy Detailed parts are sensible The winches have awesome, the brakes work and hold well All reeving works perfectly-you can easily boom up and down and luff up and down Instructions are pretty clear and logical Packaging is superior Boom tips are black Details are superior Braided line-not musky master but close It has aircraft warning lights on the boom tip Booms all the way up and down on its own-you could lay it out 2" off the ground and it is rock solid Overall the big trick is getting the weight of the crane evenly distributed across the counter weight pennants and the back mast pennants Overall this model is worth every penny!! A few pictures to share, and again 82 in total on the web site Again plenty more on my web page! Thanks for looking!
Who won? Paul or Bob? hmmm I think paul did!!
All I can say Bob is amazing! You must have some patience to set that beast up! I dont have enough of that to figure out how to set up the hook on my Mammoet LTM 1070...lol...gonna have to get you to send me a PM outlining how to do it!
Greg
finished product turned out good sir
Yup...and I liked the ending family portrait...
Beautiful job Bob!! Want a couple plane tickets to MD for some PTC rigging?, please bring you table saw.
Joined: 1/23/2007 Posts: 3,636 Location: Staten Island NY
Awesome job Bob!
Nice crane, wish I had the money for one. Can it lift that Marshall Half Stack? Andrew
Joined: 6/18/2007 Posts: 1,025 Location: South of the Weminuche
Well, Bob, it looks great. I had my wife take o look and she asked me if I had crane envy. I'm just like all the rest of the forum, wishing I had room in addition to the funds. Happy Birthday!! https://www.facebook.com/pages/Elis-Hobby-Diecast/803248369690387?ref=hl
Joined: 1/11/2007 Posts: 9,019 Location: Lincolnshire
Bob, Great post! I am glad that you have it all finished and are able to enjoy this fabulous model. I do concur with all the points you bring up, both negative and positive. Fortunately I did not have the trouble with the CW tray and suchlike that you did. But it appeaars you are not the only one and that I got lucky. Now for the team UK results: 68 minutes for the main boom and luffer. 160 minutes for main hook (lost 10 minutes here because I had to start again!) and small hook which is a total of 228 minutes. Plus I did it all on my own so do I get bonus points Paul R
Hi Guys,
I totally agree with you Bob with all the comments that you made,only the problem I had with the counter ballast reeving was worse, line got jammed around the spools, around the shafts of the spools and at the end,as well as the line guides, only solution to take it off and replace all the line, with 18lbs Musky Master. I also had problems with all the back, and boom mast stays, but I re threaded them and now fit like a dream, as you say this is an excellent model, as the detail is just fantastic, and is a real talking point.
Steve B.
Hi !
Very good review , nice pictures , very informative !!! thank you all for sharing .
The Frenchman
Joined: 7/31/2005 Posts: 5,487 Location: Breisach, Black Forest, Germany
Hey Bob, i really like the suppport base on which you placed the model while browsing your pictures, one thing caught my attention: is that glue on the cylinder? like fumes of superglue or something?
, Moderator
Congratulations to Paul R on the winning time, beating Team USA by 11 minutes!! Hats off to you!! As for plane tickets, PM me and I will give you the address to send them to! Christian-yup that is some super glue which has since been touched up. That particular back stay inserted bottom piece fell out and required a touch of the Super glue to hold it back in place. In retrospect I should have used a two part epoxy and still may do so as there is no real weight on the piece in its current position. And I did find the counter weight trays to be the trickiest part! Many interdependent connections! I am not sure if it could lift my mini Marshall stack (the noise maker as the wife calls it). But I do want to make a tank vessel like a coker to hang under neath it. Wit this model up and in house, what else is there to look forward to?.................................
Bobm2004 wrote: Wit this model up and in house, what else is there to look forward to?.................................
what about the DS system for the PTC? or a MSG80 model? remind you the MSG80 has over 30.000 tonmeters more force than a PTC ... its advertized as 3000 tonner but blows the PTC, Twin CC8800 and similar machines away capacity-wise
I took a good look at the PTC, and extending the boom is simple, even with the angled sections.
The boom 'base' sections at the lower tie, and the top sections, have a stub piece installed on the outer chords. The head section and the lower tie are both notched here to force the stub to be longer, allowing a little more room between the pins. (likely that at the shortest boom length, the offset wouldn't allow the minimum edge distance between the pins without the notches.)
I would guess the extension kit would come with one set of eight new links to replace the current ones, probably sized for the full extension set. If you want to change the configuration to anything else, you wil need to make your own set of properly-sized links. Without trying to do the math, I don't know if the upper and lower links for a given boom length are the same, or if the difference would be of consequence at 1:50.
The mast doesn't have a similar setup, since it only works in one mast configuration. (confirm?)
BobM: To keep busy, I would suggest preparing to paint a Manitowoc 4100 Ringer in Mammoet colors, and building a Portal Gantry to go underneath it. There were good photos in the "Breakwater Solutions" brochure. Though it looks like the Mammoet 4100 Ringers use concrete counterweights, the steel boxes provide a nice large surface for the biggest 'Mammoth' logo you can make.
nice....just way to big to put on the boat......
PileDriving wrote:nice....just way to big to put on the boat...... Where are your priorities? Obviously you need to invest in a larger boat!
ulf wrote:PileDriving wrote:nice....just way to big to put on the boat...... Where are your priorities? Obviously you need to invest in a larger boat! bigger boat takes the money for the bigger models....
