Joined: 2/28/2006 Posts: 552 Location: Ruthin, North Wales
Weldex have had their new LR11350 delivered to a windfarm project in North Wales Boom sections  Car body  70t track  Paul http://www.heavyhaulagephotos.moonfruit.com
I have never seen boom stored inside other boom for transport. Does the larger boom have some sort of composite bumpers in it so the smaller boom can slide in it? Thanks
It is quite common to combine boom sections togeter. I have seen the CC8800 and LR 1750 shipped like this. Fritz
CheeseHead wrote:I have never seen boom stored inside other boom for transport. Does the larger boom have some sort of composite bumpers in it so the smaller boom can slide in it? Thanks Lots of KY.
JohnGalt wrote:CheeseHead wrote:I have never seen boom stored inside other boom for transport. Does the larger boom have some sort of composite bumpers in it so the smaller boom can slide in it? Thanks Lots of KY. wa ha ha ha ..... think there are some rollers there....
its done in different ways depending on the OEM
Krupp had wheels that were installed with the lower jib pins ,and a sheet metal track to roll along inside the next larger section.
Liebherr and Demag use a Teflon bumper system combined with rollers and wheels .. its a little more tricky to load em in an out without having them run away inside .. but on the bigger sections of both there is a roller and mid way a couple of little wheels to carry the section along. After its over center a couple of guys can finish pushing the section in ,, once stowed there's a chain and a pin to secure the section from rolling out , or just a pin to dog it in
Joined: 7/31/2005 Posts: 5,487 Location: Breisach, Black Forest, Germany
liebherr1160 wrote:its done in different ways depending on the OEM
Liebherr and Demag use a Teflon bumper system combined with rollers and wheels .. its a little more tricky to load em in an out without having them run away inside .. but on the bigger sections of both there is a roller and mid way a couple of little wheels to carry the section along. After its over center a couple of guys can finish pushing the section in ,, once stowed there's a chain and a pin to secure the section from rolling out , or just a pin to dog it in on the Gottwald AK450 you can even store 4 boom pieces one inside the other. Bracht does that, will post a pic of this later. the boom pieces just have little U shaped plates welded on the inside to slide them in and out
Joined: 4/20/2004 Posts: 892 Location: County Durham, Uk
good pics mate what are the chances of knowing they were coming.... Dave
my mumblings on my little world.... http://normanshowse.blogspot.com/
Get some pics of this crane all set up if you can Jason NIkl Scale Models
CheeseHead wrote:I have never seen boom stored inside other boom for transport. Does the larger boom have some sort of composite bumpers in it so the smaller boom can slide in it? Thanks and forgive this little remark, in all friendliness, but when i saw your location i had to smile, because "optimized crane logistics" is something that other Wisconsin people should give a thought or two
Chrisitian- I agree, Manitowoc as far as I know only ships one boom section at a time. What a waste.
4 Boom sections well i guess for the size of that crane ,there should be a sizable erection crane to handle those lifts and still be able to shake out the parts. i mean ,of the hip , those lifts would have to be at least 10t metric.. your not gonna do to much with a 60t support crane in this case ,like you can the AC500 series , or even the M2250. i mean even on the CC2800 an 80t was full of her to get any amout of work done from one place, just barely get 3 sections at a time laid out and installed ,the jib ,or even the luffer became another story. Even with the AC100 on the CC2500 it became a challenge to off load boom shake it out and still be able to load in stone. you can cantilever the boom but a fixed amount of stone is required for each move . and the the room to swing it around to load the stone ,, sometimes wasnt there so to think ,from a perspective of being in the seat on a 80t,,and having that boom rollup on a truck ...its gonna get very interesting fast if i swayed of topic sorry
why shake out the parts? a small forklift is enough to pull them out since the slide easily. i heard the story of a boom piece making problems to come out once, they placed the whole packahe upside and pulled the inner boom piece... the rest was gravity here is the promised Gottwald AK450 pic ©me
I thought that all boom sections were the same size, and the only difference was the length...?
xoxo Jules
Christian wrote:why shake out the parts? They don't literally pick up the boom section by the end and "shake". That's just a slang expression for taking a bundle of things, separating them, and organizing them for use.
[[ Jules wrote:] ]I thought that all boom sections were the same size, and the only difference was the length...? Check out the pieces on the AC500 luffing jib. There are some differnces in the sizes just within that jib. Boom/jib dimensions, and the size and thickness of the pieces that the sections are made out of, are in proportion to the size and capacity of the crane. Bigger crane = bigger boom. The restriction on size is transport. For example, the Lampson LTL2600 boom sections are too big to fit on a truck, so each section gets taken apart so that it's shipped in many smaller pieces.
i know what your saying ,and it makes great sense but logistically speaking is another piece of equipment and weight to deal with working out of two lanes of traffic in a "down town" type of environment .. there's usually barely enough room to set a crane up out in the country ,again why bother when you have a crane to move them around. and its another piece of equipment to get shipped out and about .. for some reason the practicality of it all doesnt strike a lot of people ,cant say I'm not struck by it either . Iron workers up here get first crack as Gradalls are considered a tool of the trade. so to keep them out of our way ,that's another reason they don't go (sorry Jesse  ) truth be said i would much rather a raising gang (lotsa fun to be had there) EDIT when i say shake out the parts i mean spread them out in a orderly fashion ,,"shake out" is an Iron Worker term for organising the bits to go at it
Dave, I just happened to be passing!! Seriously, thanks for the heads up on this one. Paul Simpson says he has only escorted one track in and he does all VDV work in this country yet VDV say the other track is there already, brought in by Van Wieren's 8x4 FH. You dont happen to know if it got escorted or not? Cheers Paul http://www.heavyhaulagephotos.moonfruit.com
