I can say it is good to be back home finally for good for awhile. I have been running around a lot, But today was good I got home to a nice new model package.
Here is what was in it.
I made this small column for this about 2 months ago and I finally get to use it.
Lining up for the transfer ramps
Looks good going over the ramps, I have about 12 Lr1750 counter weights in the column to show the suspension working
Leaving the ramps, you can see the counter weights in the column if you look close. I will probably cut the springs to make it look more realistic since they do not drive a load around at full height on the suspension.
Not the best pics lighting was alittle dim, I will get some better ones along with the ramps and the column
Jason
NIkl Scale Models
