New snow removal ‘tow plow’ technology to be used on area highways. Options · View
ConstructionSite
Posted: Tuesday, December 16, 2008 12:40:37 PM
From MN/DoT:
"ST. PAUL, Minn.—When the winter storm predicted for this weekend hits, the Minnesota Department of Transportation will strike back with its arsenal of snow-fighting tools, including three revolutionary tow plows.
The tow plows can clear a huge swath through fallen and drifted snow. They combine conventional left- and front-mounted plow blades with a blade 26 feet wide that swings out from behind the truck like a scorpion’s tail. When fully configured, a tow plow can clear two and half highway lanes or two lanes and part of the shoulder. Mn/DOT first used the tow plow on freeways in the Twin Cities including the heavily traveled Interstate 94 corridor last winter.
The innovative new plow proved so effective that the department purchased four more, said Mark Fischbach, clear roads superintendent with Mn/DOT’s Metro District. “They make our work much more efficient and flexible,” Fischbach said. “Each tow plow can clear more traffic lanes, freeing another plow to work on another route or respond to emergency situations.” Mn/DOT now has three of the plows operating from stations in St. Cloud, Monticello and Maple Grove. Two more tow plows are now being readied for service."
Those look interesting.
- Chris Smile
89cxsport
Posted: Tuesday, December 16, 2008 12:48:05 PM
thatis freakin sweet thanks for the picture and info.
Flickr Photostream
hulan
Posted: Tuesday, December 16, 2008 5:22:12 PM
yeah thats cool.....the sterling truck part of the equation is the same as I mentioned to chuck....with the exception of a different sander, and plow/wing setup....
GH
diecast_dirtboy
Posted: Tuesday, December 16, 2008 5:25:58 PM
Pretty neat! But don't you have to run over the snow your plowing...isn't that a problem? Easier to get stuck if you don't have a blade in front of you. I guess you could just mount a blade on the front so it will work. Its really cool!!!
Real men drive diesels!
apm2754
Posted: Tuesday, December 16, 2008 6:29:43 PM
You're not running over the snow with this...
Here's a link to a news article w/ video of it in action...
http://wcco.com/specialreports/snow.tow.plow.2.630304.html
- Andy
GraniteFan713
Posted: Tuesday, December 16, 2008 7:28:24 PM
That is a cool set up. Here are the "tech-specs" if anyone is interested.
http://www.vikingcives.com/pdf/VCU/Tow%20Plow.pdf
-Dave
STLModels
Posted: Tuesday, December 16, 2008 7:36:18 PM
Mo DOT has one here in St Louis and it is really cool. It was a local creation by a MODOT employee about 3-4 years ago.
PileDriving
Posted: Tuesday, December 16, 2008 7:44:52 PM
I am so glad we dont have that kinda equipment around here......we dont see much in the way of the fluffy white stuff Teeth and I'm glad!:d/ I like x-mas with sunglasses, swimtrunks, and cocktail's in the sun!Teeth Teeth Applause Teeth Applause none the less its a sweet piece!
Justin
STLModels
Posted: Tuesday, December 16, 2008 9:47:32 PM
Just watched the video, and there is a really god clip of the St. Louis one in action. I could really see these catching on for interstate clearing. The saving on fuel and wear and tear on trucks alone has got to make it worth it.
DREWSKEEZ
Posted: Tuesday, December 16, 2008 10:19:18 PM
Yikes!
I usally get pretty concerned when my snowmobile trailer gets that sideways.d'oh!
Steve
Posted: Wednesday, December 17, 2008 12:20:55 AM
I want to see what it will do in some real snow and in real conditions. Add some ice, freezing drizzle, a 30-40 mph side wind, actual snow drifts, a wet heavy snow and with real traffic breathing down his back. What do they do when the sensors freeze up ? I want to see how that truck handles snagging a piece of broken concrete sticking up at 35-40 mph. That truck will need a fair sized load of sand (for weight) to pull that thing, not to mention extra fuel for the added power it will take to pull it and the constant sidedraft from that weighted tank on the trailer added to the truck frame and axles. I can see a nightmare in the making and only limited use in a controled situation.
turbo21835
Posted: Wednesday, December 17, 2008 12:29:53 AM
Im with ya Steve. What ever happened to teaming 4 of 5 trucks up and clearing a whole stretch of highway. MDOT has started adding wings to their plow trucks, but they only use them on the shoulders. There methods are lacking also. The seem to send trucks out 20 minutes apart. First truck plows and salts, the second truck comes behind, plows all the additional snow and salt mixture off the same lane and salts yet again.
Charter Member, QBall Fan Club
http://www.facebook.com/group.php?gid=42336642940&ref=ts
STLModels
Posted: Wednesday, December 17, 2008 1:57:48 AM
I don't know about anywhere else, but the tow plow operates as part of the gang plow group here. The dump with the tow plow has a full load of salt for weight. MODOT and the City of St. Louis have been getting a lot of wing plows as well, and they are used on the regular traffic lanes. For not being in the snowbelt, St. Louis has a very good fleet of snow removal equipment. We've had almost constant light snow and freezing drizzle the past several days with temps in the teens during the day, so the trucks have been out constantly spreading salt on the roadways to keep them from freezing up. Not exactly plowing weather for the most part, but it is always nice to see the snow equipment out on the roadways.
Kyllerontherocks
Posted: Wednesday, December 17, 2008 8:42:14 AM
Most county, and a lot of city units up here have wings on them. Sheboygan County will have a tri-axle truck with a highway blade and wings on both sides running down the interstate, clearing a good chunk of both lanes in one pass. Then a follow up to widen on each side. Guess it just depends on the area, funding, types of roads, etc.
Kyle C
JTL
Posted: Wednesday, December 17, 2008 9:51:29 AM
I hope they put a sign on the back, along with warnings along the hiway that say "DONT PASS SNOWPLOW ON RIGHT" (they have em in Idaho)
I would really hate to see some yuppie skum, bleeding heart R-Tard get hurt trying to rush to a Starbucks for that "gotta have" cup of 6 dollar coffee!
Jason
towoc999
Posted: Wednesday, December 17, 2008 11:32:22 AM
Hi !
If omeone is dumb enough to pass the plow on right hand side they deserve to be curled out in the ditch !!
This tow plow might not work everywhere but it will help a lot on snow clearing !!
By the way this should be pulled by my favorite truck OSHKOSH all wheel drive and a good load
of salt & pepper (read sad) !!
