Looks like it didnt even have a load on it! Dang soft soil -Alvin.
Joined: 3/2/2007 Posts: 521 Location: Cheltenham, England
Owch!
how on earth did it happen?
Joined: 4/28/2009 Posts: 424 Location: Alberta, Canada.
Does'nt look like too much damage. Get a RTC 50Ton, pick up the counterweights and ship the crane back to headquarters.
Well ...can never have to much in the way of mats under a crane .. Thinking though ..the ground looks alot wet .....the water may have undermined the mats ..turned gravel to goo Edit.. Second look... They may have tried traversing a recent excavation ..
Q-Ball a wolf in Jesus skin ---the sorcerer of reasonable commentary  I smile & wave Sometimes I think life is just a rodeo, The trick is to ride and make it to the bell.
Damn the Bad LucK!!!!
Other than the counterweights doin a number on the engine compartment,doesn't look that bad.I'm sure it has to be looked at structually.
no ..it dosent look that bad ... but now the plan to get the crane back down and level ...and still be able to get the boom up then down ... more so ..at that degree the engine may not even start ...if it's even capable of running this is an adventure all its own ..
looks like they should have bought the LR11351 model
gbarnewall wrote:looks like they should have bought the LR11351 model The germans make stuff way more quality built! Chinese, well, they are good at making toys Nothing beats a American Made crane!
MammoetMan wrote:[quote=gbarnewall]looks like they should have bought the LR11351 model The germans make stuff way more quality built! Chinese, well, they are good at making toys Nothing beats a American Made crane![/quote] As not to offend my brethren to the south ...but Man ...sandblast the parts before the Tremclad goes on ...the paint sucks... on Grove and Terex truck mounts ... The epoxy ,airliner paint ..what ever it is used on the European Cranes is far superior
Great post. Amazing mishap...
Joined: 10/12/2005 Posts: 707 Location: northern ireland
wow!!, very very spectacular pictures!, thanks for sharing!
MACHINE PLAY TIME !! CLICKY BELOW \/ \/ \/ http://www.youtube.com/user/allistairc123?gl=GB&hl=en-GB
Joined: 2/5/2009 Posts: 1,990 Location: waterford ireland
great post obiously nothing to do with the quality of the crane more like the quality of the ground.
GusO wrote:great post obiously nothing to do with the quality of the crane more like the quality of the ground. and ultimately the quality of the individuals operating it... -Alvin.
Joined: 6/7/2008 Posts: 1,560 Location: Waterford, Ireland
You'd wonder as cranes are getting bigger and bigger every year, are they taking into consideration the ground that these cranes are going to be operating on. There must be a limit somewhere, any geotechnical experts on here to comment?
Noel.
Noel.
, Moderator
I have my doudts that anyone was even in the seat.. looks like wet ground and it just gave in under the mats. It must have gone over slowly too. That boom point is still in pretty good condition.Great Pics!!
Man that sucks just alittle beter prep and maybe this would not have happened. That is a lot of weight on wet ground Jason NIkl Scale Models
i think it could have been ALOT worse had there been more ballast!
That is a good one!!!!! I reckon ground has gone while raising the boom. As for damage, you find there is alot more than meets the eye, there will be cracked welds everywhere and the slew ring will have been seriously stressed!!!! would have loved to have seen it go...it would have started slow and then T.I.M.B.E.R!!!!!!!
Gaz
