RTG RG25 S Options · View
todd s
Posted: Friday, March 26, 2010 11:06:03 PM
So I got her all together and here she is. As far as the cab shot we added another computer screen and control panel after I took the photo.
Me, so we just drilled a 113' deep hole and that is all the spoils we got out of it.
Oakland
Posted: Friday, March 26, 2010 11:44:24 PM
That thing is huge! Great looking machine and mighty fine looking control cab! Thanks for sharing these with us.Applause
http://photobucket.com/cat627g equipment pics. theres nothing like the smell of asphalt in the morning!
todd s
Posted: Thursday, April 01, 2010 6:12:52 PM
I thought someone would notice this and call attention to it but I guess not. What makes this so special is using any other drilling techniques this hole should have yield a little over 9 yards of spoils instead of the 10 cubic feet or so that is around the hole in the photo beside me.
ulf
Posted: Thursday, April 01, 2010 7:47:23 PM
Well yes, I did notice that. Did you guys sprinkle Magic Dust over the area to make the excess disappear? Wink
gbarnewall
Posted: Thursday, April 01, 2010 10:19:29 PM
great pics!!!!
that hole and missing spoil is a bit too erie for my liking!!! lol
could be the new "Bermuda triangle" anomoly
great pics,thanks for sharing
ulf
Posted: Thursday, April 01, 2010 11:05:44 PM
I sense neither of us is quite on track here. I'm sure Todd will provide a logical answer... Cool
towoc999
Posted: Thursday, April 01, 2010 11:59:26 PM
Hi !
Wow what a nice big boring machine !! I love the interior cab view !!
thank you for sharing !
The Frenchman
brian falcone
Posted: Friday, April 02, 2010 12:40:28 AM
we just did a grading job at g donaldson in cumberland. they have several drills and pile drivers parked in the yard. some are smaller than the one in your pic but theres 2 very large drills parked there also. i was looking at them and wondered if these machines are built from the ground up as a drill?or are they built using current excavators as a base machine?
todd s
Posted: Friday, April 02, 2010 1:29:35 AM
We use a displacement auger of our own patented design. All of the spoils are shoved latterly to tighten up the surrounding ground and you have the added benefit of only having spoils for the first 3’ of hole or so to deal with. It is very handy on hazmat sites where you don’t want any hazardous spoils to deal with. Also it is the only EPA approved deep foundation method as if we drill through a lower barrier (a layer of peat in New Jersey for example) we grout the hole up as we withdraw the tooling.
todd s
Posted: Friday, April 02, 2010 1:41:10 AM
It depends on the make and model, some are built from the ground up as a drill, some are built off of duty cycle cranes and some are built off of a heavily modified excavator. The ones built off of excavators normally only use a reinforced house structure from an excavator as the undercarriage is too weak to handle the machine. For instance an IMT drill I used to run a lot was built off of a modified and beefed up Cat 375. The drill in the photo is built off of a Sennobogen crane. Bauer for example used to build their machines off of O&K machines and Liebherr machines as an option. Then they replaced O&K with Caterpillar for the smaller machines which did not last long. Then Sennobogen came along which is what the mid size machines are built off of with the larger ones using a Liebherr carrier and the smaller ones being all Bauer.
