Two Old Compactors Options · View
DumpsterToy
Posted: Wednesday, June 09, 2010 1:16:45 PM
Have never seen compactors with this type of wheels. They look as if they were home made. This dumps site is for construction waste and is located in the south end of Columbus Ohio.
DC Craneman
Posted: Wednesday, June 09, 2010 2:12:29 PM
There are some independent manufacturers that make wheels targeted to this market. It is definitely a landfill use product as opposed to solely soil compaction.
alan627b
Posted: Wednesday, June 09, 2010 4:18:53 PM
Those are what are called Caron wheels. Looks like you got a cat 816 in front, and a Rex in the background.
Alan
Cat 816: http://www.rockanddirt.com/equipment-for-sale/CATERPILLAR/816B/invnum=31532834
http://www.cat.com/cda/components/fullArticle?m=38604&x=7&id=91294
Rex: http://catd8r.com/REX--CMI--3-35-LANDFILL-COMPACTOR-C3923-283.asp
Retro grading, We Do Modern jobs With Antique Machinery
Greasemonkey
Posted: Wednesday, June 09, 2010 4:45:43 PM
I don't think those are Caron wheels Alan. Without a different picture angle, it's hard to see the tread pattern, but they seem to be different. I think they may be shop built, but it's hard to say.
Brian
ConstructionSite
Posted: Wednesday, June 09, 2010 5:17:22 PM
Nice find! That is my all-time favorite Caterpillar cab design. Ahh...memories.
- Chris Smile
Claus
Posted: Wednesday, June 09, 2010 5:17:27 PM
That first step is a doozy!
alan627b
Posted: Wednesday, June 09, 2010 7:06:33 PM
The access to the ground is usually on the right side, Claus...less stuff to step over to get into the cab.
You may be right about the Caron label, Greasemonkey...the trash wheels usually have a chevron pattern to the treads, but caron is the only name I'd heard applied to them, so I used it. I've seen one of these converted back to a dirt compactor too, I imagine they might be cheaper to buy due to the limited application of the trash "shoes".
Alan
http://www.terracompactorwheel.com/Images/Updated%20Images/Wheel%20Types%20&%20Tooth%20Options/Gallery%20Info/index.htm
http://www.cat.com/cmms/14136184?x=7#subA1
http://www.caroncompactor.com/b_products.html
Apparently they have different designs depending on the intended application of the machine...the 'chopper or caron" style wheel appears to be intended to chop bulky items like building demo and bulk items..I'll bet it would do a real job on old appliances too!
The sheepsfoot design is for soil, the tamping foot is also for soil and also rock. Probably more than you wanted to know!
LOL!
Alan
Greasemonkey
Posted: Wednesday, June 09, 2010 11:00:05 PM
Yeah Alan, I've spent way too much time welding new adapters and feet on old garbage packers to make them into dirt machines. Garbage machines tend to run with a replaceable tooth style adapter that looks surprisingly similar to a sheepsfoot configuration. But in those cases, the teeth are designed to chop and cut the garbage. Some older designs used the chevron pattern , but these days, it seems like they prefer those in industrial landfills and transfer stations like you said since they only chop up the garbage and don't pack it. I see what you mean, Caron being a well known name, they get used to describe all trash wheels. I wonder if these started life as a set of the chevron blade style wheels and someone added on to them. Who knows, they could have been built by Caron at one point, and may have been modified later on, or maybe Caron used to make that design. I think set of those would look great on one of those 815Bs your working on.
Brian
alan627b
Posted: Thursday, June 10, 2010 7:17:47 PM
Greasemonkey, there is an easier way...Joal still sells the Cat 825B model, they just took the Cat decals off of it and sell it under the Compact label with different graphics. It also has the Chevron style wheels already on it.
http://www.#####.com/catalog/item_detail.aspx?itemfind=JOAL271
I think they have done this with a lot of the old Cat models...Cat licensing rights are a PITA. You can buy steel signs of Deere, IH or Allis Chalmers at any swap meet or tractor show for about $20, but the only ones I've seen of cat are sold by CCM and cost $120. Oh well.
Alan
