Just learned about this new beast!! The lifting capacities of the Bigge Heavy Lift machines are unmatched. The design currently in production, the Bigge125D, offers a maximum lifting capacity of 4,000 tons with a load moment of 125,000 Tem. A larger design is also in production and exceeds the lift and load moment capacity of the 125D. These machines allow for the handling of loads in excess of 1,000 tons at radii far exceeding the largest cranes traditionally used for heavy lift operations. In addition to the tremendous lifting capacity of the Bigge machines, they also offer low ground bearing pressure, configuration flexibility, and incorporation of high performance lift and slew speeds for maximum production capabilities. Significant safety features include redundant braking and leveling systems and enhanced structural robustness for operation in high wind speed conditions. Load positioning is aided by GPS tracking systems and all lifting operations are performed by a single operator. Anybody else know of this? heres the link
cranedude07 wrote:Just learned about this new beast!! The lifting capacities of the Bigge Heavy Lift machines are unmatched. The design currently in production, the Bigge125D, offers a maximum lifting capacity of 4,000 tons with a load moment of 125,000 Tem. A larger design is also in production and exceeds the lift and load moment capacity of the 125D. These machines allow for the handling of loads in excess of 1,000 tons at radii far exceeding the largest cranes traditionally used for heavy lift operations. In addition to the tremendous lifting capacity of the Bigge machines, they also offer low ground bearing pressure, configuration flexibility, and incorporation of high performance lift and slew speeds for maximum production capabilities. Significant safety features include redundant braking and leveling systems and enhanced structural robustness for operation in high wind speed conditions. Load positioning is aided by GPS tracking systems and all lifting operations are performed by a single operator. Anybody else know of this? heres the link kind of old news buddy... There have been a couple topics posted about this with info on them. A beast yes ;) just wait till you see the first photos of it! Nothing like it in america or the world!
I was thinking I heard about something like it but couldn't remember, still excited to hear about it, can't wait to see pics of it
Sarens SGC 120 crane is 3200t and 120.000 tm..... less crane with the same amount of tm
im looking forward to seeing pictures of the Bigge unit.... and a bigger one is planned too, thats insane....
Bry, get us some pictures man, you work for Bigge. what the hell!?
Haha, I just can't believe bigger and stronger cranes keep coming out, can't imagine what will be available in 10-20 years
Joined: 9/3/2005 Posts: 433 Location: One of the smallest countries with most big cranes
Where's the counterweight??? www.emielschoonen.nlGreed isn't going anywhere. They should put that up on a billboard across Times Square!
Looks like it is anchored to a large concrete piling set in the ground.
Definitely not mobile
Jerry
jdofmemi wrote:Looks like it is anchored to a large concrete piling set in the ground.
Definitely not mobile A rig this large, in nearly all case scenarios would need to be anchored in some way to the earth.
the Sarens SGC 120 crane doesnt appear to need to be anchored to the ground.... i would think this Bigge crane would need to have some sort of counterweights
Joined: 8/4/2009 Posts: 343 Location: Gothenburg, Sweden
I find it's extremely rare and weird to anchor it to the ground instead of simply putting some counterweight on it. "Hey, I got a tree root in my garden, come rig the crane here!!"
//Alexander
Hmmm..... if there was ever a model of this crane I wonder if you would have bolt it to the shelf/floor to anchor it
In the illustrations above, it certainly appears to be mounted to a yoke centered in the slew radius. Interesting...The counterweight trays may have simply been left out by the artist for some reason.
DContractor wrote:In the illustrations above, it certainly appears to be mounted to a yoke centered in the slew radius. Interesting...The counterweight trays may have simply been left out by the artist for some reason. But that doesn't make sense  Or they have just made a temporary thing in the CAD pictures to attach the superlift to, and maybe there will be some kind of counterweight in the centre of the ring, but which is left out in the CAD pictures. Because when I think about it, making a huge, deep concrete foundation in the ground just for a crane to make some heavy lifts makes even less sense...
//Alexander
Joined: 9/6/2006 Posts: 675 Location: Southern Ontario Canada
that set up would work well in a long term facility to build and then to maintain it... but wouldnt be practical to install just for a few lifts unless they could incorperate the anchoring system in the plant at some point.
DContractor wrote:In the illustrations above, it certainly appears to be mounted to a yoke centered in the slew radius. Interesting...The counterweight trays may have simply been left out by the artist for some reason. The artist left out a lot of things on the crawler with the luffer to the right.
cant wait to see it once its all completed
Joined: 8/2/2010 Posts: 87 Location: north east england
perhaps they are working along the lines of a tower crane base,a large volume of concreet below ground to anchor off. when the jobs done just cut it off and your done. maybe there thinking it would be cheaper to pour a anchor slab than truck in a load of ballast then truck it out when there done. it would free up a lot of space where the ballast would normally be
Ever been to Jenkinsville, South Carolina? Could (possibly) be worth a visit in the approaching future. I am curious to see how well this anchor point idea works in actuality. - Chris
