I am wondering if these came with Cooper-Bessemer engines ? Reason being, General Electric locomotives use to be powered by these same engines.
Cooper-Bessemer's sound an awful lot like them. Just as the old Alco locomotive had their own unique sound,the CB's sound like old GE units.
If so, I wonder where mining company's get parts for these shovel engines ?
Um I'm confused. BE 295B shovels are all electric. Well apart from those at Beener Coal. They were Cummins....I think
Regards
Mark Bridle
, Moderator
Mark is correct, All BE 295 shovels are straight electric with the exception of the Tri-Star Mining units, which are shop built diesel/electrics and they use Cummins Engines. The older has twin V-16's I think K-series and the newer unit has a single QSK-60 V-16 at 3,000 hp.
Joined: 8/23/2007 Posts: 2,639 Location: Pennsylvania
TimT wrote:Mark is correct, All BE 295 shovels are straight electric with the exception of the Tri-Star Mining units, which are shop built diesel/electrics and they use Cummins Engines. The older has twin V-16's I think K-series and the newer unit has a single QSK-60 V-16 at 3,000 hp. Tim, correct me if I'm wrong, but arn't those two the largest diesel shovels in the world now?
-Justin "Everyone's Goal Is To Mine More Coal!"PAmining http://www.youtube.com/user/PAmining
As a cable machine, I think they are the largest diesel powered. But there are hydraulic shovels that beat it I would say.
Brian
Greasemonkey wrote:As a cable machine, I think they are the largest diesel powered. But there are hydraulic shovels that beat it I would say.
Brian Yeah that's what I meant, thanks.
TimT wrote:Mark is correct, All BE 295 shovels are straight electric with the exception of the Tri-Star Mining units, which are shop built diesel/electrics and they use Cummins Engines. The older has twin V-16's I think K-series and the newer unit has a single QSK-60 V-16 at 3,000 hp. Thank you Tim T & Mark. Found a video of a Tri-star mining shovel on this gentleman's you-tube. Love the sound ! http://www.youtube.com/watch?v=53qJr3_C9SQ
Brian Brian, What shovels do you guys operate in the tar sands ?
JustinE wrote:Yeah that's what I meant, thanks. I figured that's what you meant Justin. FiatAllisHD41 wrote:What shovels do you guys operate in the tar sands ? We have P&H 4100TS, 4100 BOSS, 4100C BOSS, BI 495HF, 595B, and a Marion 351M. There were also Marion 301Ms here, but I believe they have all been retired. The 351M may have also been retired, and the 595Bs are in the process of being retired. Brian
Joined: 5/10/2006 Posts: 962 Location: Ras Al Khaimah, UAE
Brian Are you sure the 595Bs are being retired????? I thought it was the 495's that were being retired! LOL
Brian, Does the BE 495 have the 595B and 351M lower works, is it the original 495 BE bits that actually give the most probs, if the question is indiscreet then I understand.
regards Kevin
