Crane Free! A Ozzy D10 family Updated with how to do resume Options · View
RPFowler
Posted: Thursday, February 24, 2011 10:18:43 PM
Here are a few pics of what I have been quitely beavering away on. A family of Australian contractor D10's.
The one on the bottom left is an original.The rest have all had the treatment!
Here again is an original on the left, with one of the converted!
These two are converts!
And finally the 3 together.
Enjoy!
KR
R Think
FiatAllisHD41
Posted: Thursday, February 24, 2011 10:45:30 PM
Handsome looking D-10's !!!! Excellent detail !!!
-Unknown
FiatAllisHD41
Posted: Thursday, February 24, 2011 10:46:41 PM
Sorry for the double post.
-Unknown
plumber
Posted: Thursday, February 24, 2011 11:42:48 PM
Very nice!Applause The hydro lines look awesome. Did you add these? I'm sure there are those out there who know this right away, but who makes that particular model? You will have to forgive me, I'm a little new to the customizing game.
Shay Stutsman
Posted: Friday, February 25, 2011 12:12:57 AM
Richard,
You truly are an amazing modeler, fantastic work!
Sincerely,
Shay Stutsman
ulf
Posted: Friday, February 25, 2011 12:15:42 AM
The big Cats are great looking models anyway, but your detail work really adds to the package. Very nice! Applause
Eskimo
Posted: Friday, February 25, 2011 12:31:40 AM
That is amazing work thanxs for sharing with us!!!
skizmog
Posted: Friday, February 25, 2011 4:17:32 AM
Where did you get those cab lights? The models look great!
-Brett
Robert Heuston
Posted: Friday, February 25, 2011 4:31:19 AM
I really like the Abi group unit.
BruceD
Posted: Friday, February 25, 2011 5:16:16 AM
Nice engine swap can we get a close up of that. The decking looks different on the 3 you have worked on?
Very nice work Richard
Gavin84w
Posted: Friday, February 25, 2011 6:17:07 AM
Hmmmmmmmm, those are my kinda tractors!!
Stunning mate, just as i have seen them in years gone by.
footloose52
Posted: Friday, February 25, 2011 6:26:33 AM
Really great work, my abilities are certainly not cut out to do anything even close
I reckon they all look perfect,, and great pictures
Regards from down under
Peter
Gd10r
Posted: Friday, February 25, 2011 3:15:31 PM
Looking good, that is one fine fleet. Donors should be arriving for transhipment today.
G
Still Plays with Toys
footloose52
Posted: Friday, February 25, 2011 8:21:48 PM
What are U doing up this late Richard?
RPFowler
Posted: Friday, February 25, 2011 8:38:42 PM
Here are a few "progess" pictures and quick run down of what is involved.
Completely strip down. This is not for the faint hearted or easily impatient! The plastic block right underneath has to be popped off first to reveal the screws. There are numerous tricks and processes required to do this without damaging things! Note what are plastic and what are metal bits. Carefully remove cab glazing. Strip the metal with a pickling solution of nitromors with additional methylene chloride. Tracks are not fully stripped by this method, so into hot caustic soda, at a concentration which when added to the hot water causes the water to boil. Leave in this for 12 hours before strong brush off and clean off! Plastic parts where still needed, if need stripping use a mild cool solution of caustic soda.
Engines.
Here are a few stages, all on one pic! Start with making a new master block, which entails very visible differences and hence changes to the heads, turbos, ancilary pipework and covers and then cast the new resin block.
Then make bend up all the new pipework masters, muffler shields, air cleaner filter casings and cast in white metal and then fit.
Here is a sprayed up comparison.
Top Deck.
Grind off all the top deck clean flat. Open up coreldraw and create the new treadplates, steps etc. Etch the brass (8 thou sheet) and fit. Make new white metal patterns and cast the step supports. Fill in holes for pipes to front rams, drill new holes and fit brass rod fittings.
Drill the holes in the hood. Fill the old ones etc. These need to marked very carefully, supported, punched and milled flat. Note the new twin stacks are slightly offset and forward of the single stack, which makes drilling much more difficult.This has to be piloted through from the back. Fill sides and sand smooth. Then Refit handrails.
Drill out all the holes in the hydraulics for ripper and back plate and insert brass rod fittings, 4 on each side. Fill hole on the side of the rops where the fire extinguisher was and file to match mounts profile.
Once sprayed up with acid etch, 2 coats yellow primer and 5 coats of top coat, (this is Holts professional top coat cellulose). This also shows how all the pipes line up under the holes and the exhausts and air intakes are stuck onto the top of the pipework underneath the hood, just like in the real machine.
Carefully reassemble. Plumb up with silicone tube. Fit swarovski jewels into all the lights and work lights (work lights and front head lights are white metal). Bend up exhausts to fit. Spray off black along with the air cleaners.
For the Australian machines additional plates are fitted to the centre of the front blade for scraper pushing.
Back to Coreldraw to make up the new decals. Print, seal and apply with microsol. Add fuel tank overspill hose and job's about done!
Enjoy!
KR
R
Teeth
a Cutter
Posted: Friday, February 25, 2011 11:14:58 PM
Way to go Richard! You do it so well, the new features just blend right in.......beautiful 10s for sure.
Chris
Gavin84w
Posted: Saturday, February 26, 2011 5:02:53 AM
2 columns of CARB,s nightmare coming out of the stacks and they would be lifelike!!!!
Kevin Bridle
Posted: Saturday, February 26, 2011 7:27:32 AM
fantastic work Richard, brilliant description of the hard work that goes into making customs, your efforts to show us are much appreciated.
regards
Kevin
RowanH
Posted: Saturday, February 26, 2011 8:53:42 AM
Applause Applause
Amazing work as always Richard! Loved seeing the progress pictures. Nice to see some local liveries too!
Rowan.
Mongolandre
Posted: Saturday, October 20, 2012 7:33:58 AM
Absolutely stunning! Congrats, sir!
He who asks is a fool for five minutes, but he who does not ask remains a fool forever.
