Joined: 7/26/2010 Posts: 807 Location: Lansing, Michigan
Zack
"You can take the kid out of the sand box , But you can't take the sand box out of the Kid."
Zack, definitely looks way better without the ripper on but I think if your going to make a quick coupler for it lose the boxy thing on the bucket and put the "hooks" directly to the bucket and also make the coupler on the machine a little smaller.
I would have used the coupling that you took off the bucket for your coupler base as it is already set up for the linkages.
Good luck!!
dain555 wrote:Zack, definitely looks way better without the ripper on but I think if your going to make a quick coupler for it lose the boxy thing on the bucket and put the "hooks" directly to the bucket and also make the coupler on the machine a little smaller.
Good luck!! thanks dain for the help, will do. yeah i would have 2 but it has the curve of the back of the bucket so in order to drill a hole for the bottom of the "hooks" to be locked in with a pin. so i'll see what i can do and post another update on here later. -Zack
Zack "You can take the kid out of the sand box , But you can't take the sand box out of the Kid."
A lot better looking with the hooks only on the bucket!! As you said, "now to clean it up and get it sanded", also a nice paint job!! Can't wait to see the other attachments too!!!
dain555 wrote:A lot better looking with the hooks only on the bucket!! As you said, "now to clean it up and get it sanded", also a nice paint job!! Can't wait to see the other attachments too!!! Thanks, it was a pain in a#$ but i like the end result of it now this week i'll be makeing forks and a sand bucket and maybe if i have time a sand bucket with a top grapple like Brandenburgs trackloader  -Zack
Another bucket that would look nice is a demolition bucket with the top grab like the First Gear Internationals do!!
dain555 wrote:Another bucket that would look nice is a demolition bucket with the top grab like the First Gear Internationals do!! I know right!! -Zack
