WCKrueger wrote:Hunter
The 18mm Conrad tracks are a little wider, but would look ok (IMM). You might have to modify the sprocket and idler and you would need two sets to get the right length. At 38.00 a set you might want the front shovel (if you can find one) for the extra parts and ease of modification.
Wes
If you're not a stickler for authenticity, (the 365's normally having double grouser tracks, rather than triple) The Hitachi 450zx tracks are also 18mm, and fit on the norscot rollers with minor to the rollers modification, however for a 365 you'll need a third track to get a few extra links, (which in my case is never a problem! this is about half of the 450's in my shop)
Eric W. Pioszak, Operating Engineers Local 701, Portland, OregonMETAL TRACKS AVAILABLE AGAIN! Cab guards Available again!
Grapples Available again!
