Underground Cats Options · View
BAH
Posted: Monday, December 19, 2011 5:14:54 AM
Something for the “Underground Mining Boys” This was the first of 3 graders I modified to suit underground mining. Overall height had to be reduced to 2.5 meters. It was an interesting project with a lot of things to take into consideration while redesigning the machine.
Robert Heuston
Posted: Monday, December 19, 2011 6:28:07 AM
Saw something similar down here in the valley not long back.
JTL
Posted: Monday, December 19, 2011 2:26:01 PM
A few years ago, the Cat house in Billings, Montana did the same thing to a 120 for the Stillwater Mining company. They did big write up on it in their newsletter. Very interesting re-build, thats for sure.
I wonder how long it will take those miners to have that thing looking like a bomb hit it? Kinda like everything thing else that goes underground!
MJW
Posted: Tuesday, December 20, 2011 6:50:22 AM
The South African Cat dealer Barlow has done quite a lot of conversions for underground machines, including graders and dozers. They told me there's a lot to it, not just lowering the cab. All the electrics and hydrualics have to meet underground safety regulations and that can be time consuming. And yes, a few months underground and a few strikes against the tunnel sides and even a new machine can look like it's pretty old.
RowanH
Posted: Tuesday, December 20, 2011 8:07:00 AM
That sure is an interesting looking machine, totally throws the dimensions off. Looks like a very professional professional conversion, where did you source the cab from?
Rowan.
BAH
Posted: Tuesday, December 20, 2011 8:46:38 PM
@ Rowan: I design the cabin, it has full FOPS certification. The roof plate is 20 mm (3/4”) thick to limited impact deflection in the event of a cave-in. It also has a 75mm (3”) heavy wall pipe extending out the side to help protect the cabin from wall impacts. It’s a lot different in concept to a traditional grader cabin. All grader cabins have a front windscreen that slops forward for better visibility and so the dust doesn’t hang on it. The problem underground is the drives are curved in the corners and if the windscreen was to sloop forward in makes the doors winder at the top. By slopping the window back it makes the doors narrower at the top therefore they are less susceptible to damage and makes it easier to get out in a hurry. The driver actual sits on the original cabin floor with his legs straddling either side of the main frame.
@MJW: there is more work in reconfiguring the grader controls that making the cabin. Every thing has to be relocated. In this case we even had to shorten the blade lift cylinders buy about 60 mm so they would clear.
RowanH
Posted: Wednesday, December 21, 2011 9:06:25 AM
Very interesting reading BAH, thanks for sharing.
Rowan.
