VERY HEAVY LIFTING CABLES Options · View
RI CRANEMAN
Posted: Saturday, January 14, 2012 1:12:16 AM
It was a very rainy day yesterday; a good day to build something. Here are some heavy lift cables I made. I currently don't have anything to attach them to but maybe soon.
Tom
PileDriving
Posted: Saturday, January 14, 2012 1:54:40 AM
Nice...Looks a lot like tri-flexs
Justin
ulf
Posted: Saturday, January 14, 2012 4:51:39 PM
Those look terrific...Applause
JSW57
Posted: Saturday, January 14, 2012 5:24:31 PM
I agree Whistle
Jeff
Paul A
Posted: Saturday, January 14, 2012 6:08:30 PM
Got to agree those look excellent wish i could make things like that.
Take it to the limit and then just a bit more
VIPCranes
Posted: Saturday, January 14, 2012 7:28:16 PM
well done craneman they look awesomeApplause Applause Applause , just made me a long pair along with a heavy lift bar tooTeeth
SOMETHING IS BETTER THAN NOTHING.
http://s1185.photobucket.com/home/vipyfz2008/index
http://www.youtube.com/user/vipyfz?feature=mhee
luis.
Paul
Posted: Saturday, January 14, 2012 8:22:13 PM
Great job there Applause
Are they quite flexible?.
Think of the size of spreader bar you could make for them!.
allisoes
Posted: Sunday, January 15, 2012 1:33:37 AM
The cables look great. What material did you make them out of? How did you get such small crimps ?
RI CRANEMAN
Posted: Sunday, January 15, 2012 3:08:38 AM
Ed, The cables are made from 1/16" tarred nylon line. It is used to mend fishing nets.
The aluminum tubing is 0.235"OD x 0.160"ID x 0.040" WALL
The cables are three part line double looped at each end.
I use a set of crimping pliers that I got from AC Moore.
It's a tight squeeze but four parts of line will fit through the ID
I work around the middle of the crimp and then use a round file to smooth every thing out.
Paul (thorleif) The cables are nice and flexible.
The line splices very well also.
Can anyone guess how to keep the lines twisted together so they do not unravel?
Tom
Paul
Posted: Sunday, January 15, 2012 11:47:19 AM
Cheers Tom, that was very interesting to see how you made them and I think I even have a roll of the nylon line you used.
I suppose you could use a little superglue here and there to stop it unravelling but the down side of that is that it will probably become quite inflexible.
Smile
SDBOB
Posted: Tuesday, January 17, 2012 12:12:02 PM
Thanks Tom. Jeez the way you explain it-I can do that. Bob
Bobm2004
Posted: Tuesday, January 17, 2012 3:45:22 PM
Groups: Member , Moderator
I love when one hobby crosses over to another. As some of you know I crack bull and stock whips for fun-it can find pictures in the lounge-and one of things a whip cracker needs to know how to do is to replace a popper, the end of the whip that actually breaks the sound barrier and makes the crack noise. To make a popper you usually take nylon line and twist it together in such a way as it holds the twist.
Making a popper midwest whips
EM Brands
Bob
Bobs Cranes
allisoes
Posted: Wednesday, January 18, 2012 11:45:49 PM
Thank you. I am not sure. If I have to guess, do you put it in the microwave to bond the tarred lines together?
RI CRANEMAN
Posted: Thursday, January 19, 2012 2:11:49 AM
Ed, Microwaving won't bind them together. Microwaves only excite water, sugars and, fats. I used a heat gun used for embossing. It works really well. The nylon line takes a good heat set.
Tom
a Cutter
Posted: Thursday, January 19, 2012 1:45:20 PM
Applause
Love the 'walk through'......great accessory!
Chris
dain555
Posted: Thursday, January 19, 2012 2:23:30 PM
RI, cuddoes on the cables!!!
I have never thought of using aluminum tubing for crimp tubes. I have the crimping pliers and I have the small jewelry crimp tubes too but the ones you made are nice, will have to try some. I have some heavier leader line that the small jewelry tubes have a hard time crimping.
I guess I need to find some of the nylon line the other half crochets with and make some lifting cables!! She has some line that is blaze orange!!!
TimT
Posted: Thursday, January 19, 2012 3:35:06 PM
Great Job!!!, they look just like these.....
allisoes
Posted: Thursday, January 19, 2012 6:18:18 PM
Very interesting. Do you treat only the part that is doubled up and under the crimp, or the entire length?
What size shackles look good with it?
PS you are a great teacher !!
Cat 966f
Posted: Friday, January 20, 2012 12:47:27 PM
Great job! They look great Applause
-Vinny
http://www.heavytruckphotos.com/
