Lr 1300 help Options · View
bigdan45322
Posted: Wednesday, August 08, 2012 4:52:44 PM
Ok I have my 1300 put together but I canot get the a frame portion to come down so I can lower the boom by my hand. But I tryed it with the key in my drill and it worked great up until the head broke off now I have no way of raising or lowering the a frame. Any one have any ideas thanks
Steel makes the world go round that is why I pride my self with the work I do. I am a proud steel mill worker.
Dan
DeWoc19
Posted: Wednesday, August 08, 2012 4:58:32 PM
spin the drum with your finger Eh?
bigdan45322
Posted: Wednesday, August 08, 2012 5:26:24 PM
It will not spin with my hand.
Dan
Posted: Wednesday, August 08, 2012 5:37:38 PM
Yes if I remember right there is some kind of reduction gear for the A frame. Can you contact NZG and get a new key? I'll have to say that the A frame is very stiff.
bigdan45322
Posted: Wednesday, August 08, 2012 5:48:31 PM
It was actually not the key that snapped off but what the key attached to to turn it.
Dan
bigdan45322
Posted: Wednesday, August 08, 2012 6:15:30 PM
Also how do I get ahold of nzg
Dan
Posted: Wednesday, August 08, 2012 6:17:28 PM
info@nzg.de
chevyman
Posted: Wednesday, August 08, 2012 6:20:54 PM
I did the samething with my 855. I emailed NZG and they said they do not have the piece for replacement. Its the stud that the winding tool slide on in the drum.
Mike
bigdan45322
Posted: Wednesday, August 08, 2012 6:30:49 PM
How did you solve the problem mike??
Dan
chevyman
Posted: Wednesday, August 08, 2012 6:36:30 PM
I haven't yet. I used the whip line to reeve the a-frame. Maybe some one could turn a brass piece on a lathe, then file the one end square for the tool to fit. I don't have access to a lathe to try it.
bigdan45322
Posted: Wednesday, August 08, 2012 6:40:08 PM
Ok I wonder if they have a whole drum assembly.
Dan
chevyman
Posted: Wednesday, August 08, 2012 6:43:35 PM
I never ask about that. I just sent them a pic of the broken piece and they said no parts. Let me know if you get anywhere with a whole drum assembly as I try that.
VIPCranes
Posted: Wednesday, August 08, 2012 6:48:17 PM
Same problem with my. Is a shame that nzg cant help with some of their models parts. Even on my 11200 the same problem happened.
SOMETHING IS BETTER THAN NOTHING.
http://s1185.photobucket.com/home/vipyfz2008/index
http://www.youtube.com/user/vipyfz?feature=mhee
luis.
bigdan45322
Posted: Wednesday, August 08, 2012 6:56:50 PM
Ok I sent them an email. If I can't get the whole assembly I'll take and drill and tap it with a screw and put super glue in it.
Dan
chevyman
Posted: Wednesday, August 08, 2012 6:58:11 PM
Maybe someone here could turn some out of brass rod? I wouldn't think it would be too hard. Then file the areas that need to be square. If someone with a lathe could do this I'd buy a few to replace the ones on my 855. I could mail my broken one for measurements.
chevyman
Posted: Wednesday, August 08, 2012 7:00:25 PM
I assume the piece for the 1300 is bigger then mine. I dont think mine is big enough to drill and tap.
cranedude07
Posted: Wednesday, August 08, 2012 7:01:46 PM
They never should have designed it with that gear mechanism I think. Mine to is very hard to turn, but I keep the Derrick on as I can easily boom up or down using it instead of the a frame. My hs855 isnt that hard to wind, but I still don't like the design of how to wind it up, just made it difficult
Brandon
my youtube channel
My Facebook Page
VIPCranes
Posted: Wednesday, August 08, 2012 7:19:01 PM
We all need to send an email about the same problem last time i emailed them they told me the same thing. No parts for that paricular model. Is a shame. Not like conrad they have most of the parts well at least the ones i was asking for.
luis.
bigdan45322
Posted: Wednesday, August 08, 2012 7:31:50 PM
Thanks Brandon I should have asked you more questions on it before buying it. But now I know. And mike mine is sheared off at the gear and I have miniature taps.
Dan
Robert Heuston
Posted: Wednesday, August 08, 2012 8:55:56 PM
The A frame line on my LR1300 is tangled around the spindle that the drum is on. When I get home I'm going to have to try and de-rig the a frame and un tangle it all.
