NIce pics, I was thinking about making a cable drum like this for a load, you anyone be interested if I ever did a few? Jason NIkl Scale Models
Take a close look at how the 18000 is reeved. Seems odd. They have the rooster mounted only to use it for the dead end. Plus the hoistline is reeved backwords through the block then the conventional way. I would assume they did that so the dead end would be on the outside of the block so it could go to the rooster. I do not really know a lot about Manitowocs, but this does not seem right? Does anyone have other photos of any 18000s that are reeved this way?
Lol I asked a similar? Awhile back on my Manitowoc page posted this? Fellow operators who run 18000 said its right way its rigged up. Due to the configuration it is. So yah it looks odd but its correct
Here is the rigging diagram for the head On the 16000 it applies to the 8 and 10 part. On the 18000 it applies to the 2, 4, 6, 8. and 10 part Where it gets tied off to the upper point. I know it's odd but on the 16000 and 18000 there are 2 reeving schematics for the main block that require the upper boom point. I think it was 12 and 14 part lines? You reeve every other sheave and lace it up like an old pair of sneekers and use the sheaves you skipped comming back to center. If you are not in line with an anchor point at the end you use the anchor point of the Rooster.
Very odd. It must be a special type of hoistline. Normally you would always keep the hoistline moving in the same direction to avoid damage to the core.
I've tried to open the photos, right clicking and show pic. doesn't seem to work. I tried refreshing,different cable still nothing.Is it my computer or cable? Any computer experts out there can help me?This seems to be ongoing . Bob
Told you Ben this am the pics came up!I am at work on a different line soooo.Thanks Bob
