Heavy Haul Cat 385CL/ Custom Additions Options · View
CAT324DL
Posted: Sunday, June 30, 2013 2:35:37 PM
Hey guys, just sharing some new additions to my CCM Cat 385CL, and some heavy haul photos. I have added etched walk ways on top of the model, new air intakes (yes I know they are on the wrong side, but it was the only place I could put them where it wouldn't hinder the opening compartments.) I will be redoing the hydraulic lines as well, something a little more aggressive.
-Mike
Antho
Posted: Sunday, June 30, 2013 3:09:24 PM
To make it look a bit more realistic, take the tracks off and remove the 4 little screws that hold the track frames to the main undercarriage frame. You could put small wood blocks under it too to make it look even better. The screws are easy to see, they're on top of the main track frame between the top rollers.
linkbelt290rb
Posted: Sunday, June 30, 2013 3:22:10 PM
[quote=Antho]To make it look a bit more realistic, take the tracks off and remove the 4 little screws that hold the track frames to the main undercarriage frame. You could put small wood blocks under it too to make it look even better. The screws are easy to see, they're on top of the main track frame between the top rollers.
Around new england, we just take off the counter weight, stick/bucket.
Nothing runs like a deere with a cat on its back but the link belt ate both of them
CAT324DL
Posted: Sunday, June 30, 2013 3:22:20 PM
Thanks Antho. I always thought it would be a pain to take the tracks off, but if it's that easy, I'll have to give it a try. Now if only CCM made it so the counter weight came off...
-Mike
catman15
Posted: Sunday, June 30, 2013 4:07:33 PM
I like it, very nice work! Applause Applause Applause
-Bob
laurent o.e.987
Posted: Monday, July 01, 2013 6:14:45 AM
looking good mike!
DeWoc19
Posted: Monday, July 01, 2013 9:18:14 AM
I want that low boy, that's a sweet livery!
Robert Heuston
Posted: Monday, July 01, 2013 10:14:21 AM
What wieght is the counterweight, here in Aus we'd walk it up on a Drake 4x8 or 5x8 with dolly both set at 4.0 or 4.27 meter width. Can put a ZX870 on without counterweight, scrape in just under legal wieght's.
CAT324DL
Posted: Monday, July 01, 2013 1:03:09 PM
Thanks
laurent o.e.987 wrote:
looking good mike!
Thanks!
Thanks Dewoc
The counter weight weighs approximately 25,600lbs. Correct me if I'm wrong.
-Mike
cranedude07
Posted: Tuesday, July 02, 2013 12:54:24 AM
KyleS
Posted: Wednesday, July 20, 2016 1:05:57 PM
Not to bring up an old threads but I read somewhere that the counter weight on the CCM 385 is removable after taking the model some what apart. Can anyone confirm this?
- Kyle
Basketball Man
Posted: Wednesday, July 20, 2016 7:14:30 PM
It can be removed. There are two screws that hold it on inside the engine compartment.
-Ethan
Collection 8/2/2016
ChandlerYohn
Posted: Friday, July 22, 2016 1:34:26 AM
Very sweet non-slip etched pieces, the black adds to the model. I guess if you could remove the CW, then you could fabricate a plate with the CW lifting equipment and then screw it back into the model so it would look a little more natural... just a thought, but would require some fine detail work.
Thanks so much for sharing!
