I don't want to highjack Dex's post on the D350D but I just got done with my D350E project and decided to share. It still needs some lights on the front, looks like a trip to the local fabric store is in order. There are a lot of differences between the "D" model and "E" model. Let's get started. One clapped out Ertl model, Check. Heavy bed modifications, Check. No external ribs on the E series.
That looks great! How did you remove the ribs?
I've got to start messing around with brass.
Weserhutte wrote:That looks great! I've got to start messing around with brass. I can't profess to be any good, but it is fun. All done.
I just edited my previous post and found your response. How did you remove the dump bed ribs??
Looks great with other 90's era machines Just a little comparison
Quote:That looks great! How did you remove the ribs? I just took the dump box to the bench grinder and took them off. It loaded the grinding wheel,so you will need to redress the wheel when you are done. Then I covered whatever was left with some brass sheeting.
Not bad dude! What printer do you use for your decals?
Now you make me want to build one, great idea once again!
Dex wrote:Not bad dude! What printer do you use for your decals? I used a generic canon inkjet printer. I printed using Testors decal paper system. The most important thing with these decals is to keep the printer settings for standard office paper. Then I clear coated the decals to prevent any pealing.
