Joined: 5/18/2007 Posts: 1,103 Location: Port Republic Virginia
I have very recently purchased this model. It is the crane version. I would to know how to run the lines for this model for display. I bought the model second hand from an antique shop, no instructions were in the box. This my first time having to set up a crane. Thanks for any help. Flickr Photostream
I still have a few of those mothballed. I'll try digging one out to see if I have the reeving diagram.
Don't call it a comeback, I've been here for years.
Joined: 7/26/2007 Posts: 57 Location: Berbenno (So) - Italy
Foto:
______________________________ instagram: giomaffy______________________________
Thank you for the photos and diagram. Do I need to pull all of the line off the drum to run the line through? Flickr Photostream
Unfortunately I do not speak English and the Google translator is not understandable. I'm sorry.
______________________________ instagram: giomaffy ______________________________
Joined: 8/21/2002 Posts: 435 Location: in the wild blue younder
Salut Gio,
il te demande s'il doit tout dérouler le fil (câble) qu'il y a sur le treuil... Moi je ne me rappelle plus, je ne peux pas répondre....
Her fragt dich ob er soll den seil aus dem Winde ganz ausziehen.....bevor es anfangen....
Ah, ok. Oui il faut derouler le fil mais seulement de une partie. Puis avancer sur le poulies ... Regarde le instructions de Conrad. Salut. giò
Thank you, your diagram is much easier to understand. Flickr Photostream
