Liebherr A974 wheeled material handler specs/drawing search. Options · View
FiatAllisHD41
Posted: Wednesday, August 17, 2016 3:07:02 PM
Hi all,
Looking for specs on the A974 eight wheeled carrier.
Did Liebherr manufacturer this carrier or someone else ? If so who ?
Need large photos or detailed drawings of this carrier.
-Unknown
FiatAllisHD41
Posted: Wednesday, August 24, 2016 12:53:03 PM
All the Liebherr fans world wide and nobody knows ? Contacted Liebherr with no luck. I hate to assume but if Liebherr didn't write back. You think it's safe to assume they made it ?
Who made the wheeled carrier ? Liebherr ????
Can't find drawings. Your help would greatly be appreciated.
-Unknown
Mr. Scholz
Posted: Thursday, August 25, 2016 6:38:58 PM
Hi HD41,
most of the available pdfs about the A974 tend to be field reports, but atleast I was able to find a german version of the according spec sheet: https://www.yumpu.com/de/document/view/43185559/a-974-b-liebherr
If I can help you with any translation, feel free to ask.
I bet the undercarriage was designed and built by Liebherr in Colmar(France) at their mining shovel plant.
Cheers,
Max
FiatAllisHD41
Posted: Thursday, August 25, 2016 7:48:49 PM
Mr. Scholz wrote:
Hi HD41,
Cheers,
Max
Thank you Max ! This will help the scratch build expediently .
You are correct about the carrier French made in Colmar,France. Found a PDF Liebherr A974B with measurements. Carrier length 9085 mm.
Close enough for my modeling needs.
Thanks again Max.
-Unknown
