Hey, I having some trouble taking apart an axle from a Norscot scraper and I'm not sure how to separate the rod from the wheel. If any one knows how to please help.
They are knurled axles, just takes some force, but they pull apart.
Put the spindle in a vice and crank it up tight. You can then pull and twist the wheel until it comes off. They are on tight, but this method works well.
Got it. Thank you both very much!
