Joined: 1/11/2007 Posts: 9,071 Location: Lincolnshire
Paul,
Sharp looking crane as well as the trucks !
Thanks for posting.
Very nice pics.
What a beauty. Cracking set of photos Bruce. Cheers for sharing Paul Heavy Cranes
Jack. wrote:What a beauty. Cracking set of photos Bruce. Cheers for sharing Paul + 1.
What Jack said...that is one cracking Crane.
JohnGalt wrote:Jack. wrote:What a beauty. Cracking set of photos Bruce. Cheers for sharing Paul + 1. Just for amusement sake, here is the version in Alaska. A very impressive chunk of iron...
Thanks, Ulf. Interesting comparison of the configurations of the rear. US version has the cradle for the boom cylinders, and the cylinders have safety stripes, for when they hang over the back. White uppers, for camouflage in the snow, with gray lowers for hiding all of the springtime road grime. Very appropriate!
I can just imagine a snow machine roaring across the "tundra" a few feet above road surface and plowing into the boom of that baby...
ulf wrote:I can just imagine a snow machine roaring across the "tundra" a few feet above road surface and plowing into the boom of that baby... My $2 perfecta in that contest would be the Liebherr for the win, and the Polaris to show.
JohnGalt wrote:Thanks, Ulf. Interesting comparison of the configurations of the rear. US version has the cradle for the boom cylinders, and the cylinders have safety stripes, for when they hang over the back. White uppers, for camouflage in the snow, with gray lowers for hiding all of the springtime road grime. Very appropriate! And it is also physically wider. Paul R
JohnGalt wrote:ulf wrote:I can just imagine a snow machine roaring across the "tundra" a few feet above road surface and plowing into the boom of that baby... My $2 perfecta in that contest would be the Liebherr for the win, and the Polaris to show. Maybe a win for the Liebherr and the Polaris is a ....DNF..or DOA. We have transmission structures built on H-Pile and sometimes to mitigate frost heaves the utility will tie the H-Pile horizontally together with 25M guy wire. One must be careful to position the wire at a sufficiently low point so the random Polaris doesn't get clothes-lined. They like to run in-between the tower legs even though they are on permitted property. Got to be alert in the Great Outdoors...
Paul R wrote:And it is also physically wider. In true American fashion... Wider tires ("tyres"), too. Probably 6 cupholders in there, somewhere.
I do not have a 1500 as yet(have 11200s, Demag 500s, 1350s, all the rest. But if that Global comes out in 1/50...it's coming to my place.
Joined: 7/10/2007 Posts: 816 Location: UK Stratford on Avon
Jack. wrote:What a beauty. Cracking set of photos Bruce. Cheers for sharing Paul Jack! Hows it going mate? Its been a while. I live in the Outer Hebrides now. Andy (AGD Welder) How to search the forums
Hi Andy, good to hear from you mate! That's a bit of a change of location!! What you doing up there mate? Heavy Cranes
GC1 wrote:I do not have a 1500 as yet(have 11200s, Demag 500s, 1350s, all the rest. But if that Global comes out in 1/50...it's coming to my place.
Yes, a 1/50 version would look awesome
Interesting to see the exhaust on the upper structure in such design. "normally" seen in this configurations
That has to do with emission standards.Higher emission standard requires higher temperature in the exhaust.Therefore the exhaust system is longer.
Dont bump you arm on that exhaust it burns your arm quick, i have a nice scar on my arm NIkl Scale Models
