Hi guys, I'm nearing the end of two custom D11 builds (don't worry, pics of the build will be up when complete) and I'm having difficulty finding how the tilt cylinder hoses are routed. Are the the same as the D9 picture below? If so, where on the machine do they come out? D9T example:
, Moderator
If you mean from where do they exit the body of the tractor... the couplers are usually in a cut out on the left side of the front grill about a third of the way up from the bottom. Most of them have two sets one above the other
That's what I needed to know, thanks.
Hi Dex, Gipicartos D11R project offers some good visual information. Tims discription hit it perfrectly, here you can see it on the front grille Gipicartos D11RLooking forward to see your D11s! Max
That photo of the D9T looks to have an extra hyd valve mounted on the RHS blade to possibly run an extra cylinder or two on the LHS looking at the mounts on the draft arm
