Was looking through a website, found some new 1:50 models coming from our friends at DM
D6 LGP VPAT #85554 D6 XU SU #85553 CB 2.7 roller #85593 309 next gen midi #85592 CB 13 roller with and without cab #85594 & #85595 301.7 mini #85597 308 next gen midi #85596
Looks like this will be an interesting year for cat models.
- Tyler
Joined: 1/20/2004 Posts: 125 Location: Alberta Canada
Did they by chance mention models from DM in other scales?
There is the cat ct681 concrete mixer and dump truck in 1:87 scale #85512 & #85514.
That’s all I’ve seen so far.
- Tyler
Any photos anywhere. Was just going to start a D6r LGP
Brad wrote:Any photos anywhere. Was just going to start a D6r LGP No pictures yet, it seems that delivery is likely around April/May this year.
- Tyler
Absolutely love DM models.Really good CAT machinery.The only thing is,the packaging.Fine if you are only going to give one,or two,as a gift,or present them to a customer.For someone like me,who collects,that has 20+DM models the metal boxes become a real problem.I now am put off by the boxes alone.My loft space is virtually filled with empty DM boxes.I want more,but the packaging simply takes up too much space.I only have room to display the models.
Cat938k wrote:There is the cat ct681 concrete mixer and dump truck in 1:87 scale #85512 & #85514.
That’s all I’ve seen so far. They canceled those last year once Cat scrapped there truck program. Unless they are back on again.
rmkulak wrote:Cat938k wrote:There is the cat ct681 concrete mixer and dump truck in 1:87 scale #85512 & #85514.
That’s all I’ve seen so far. They canceled those last year once Cat scrapped there truck program. Unless they are back on again. It’s marked as “new listing”
- Tyler
No pictures yet, description doesn’t have anything mentioning a ripper. It’s possible they will look like that however the model may vary.
- Tyler
Claus, the dozers you have pictured are D6n series. Readily identifiable by the side mounted lift cylinders. Exsisting DM models have been based on the D6r/ D6t series. A bigger dozer. I would guess the new releases would be a variation of these castings.
Brad wrote:Claus, the dozers you have pictured are D6n series. Readily identifiable by the side mounted lift cylinders. Exsisting DM models have been based on the D6r/ D6t series. A bigger dozer. I would guess the new releases would be a variation of these castings. Cat just came out with a new line of dozers that you can see in Claus' post. Their new dozers will no longer have a letter after the number. I read somewhere that some of them will get new numbers to go with the sizes. I can't remember exactly how it went but it was something like this: D3k->D1 D4k->D2 D5k->D3 D6k->D4 D6N->D5 D6T->D6 D7E->D7 D8T->D8 D9T->D9 D10T->D10 D11T->D11 Once again that may not be accurate or even if it is Cat might change their minds before it's finalized. So a new D6 dozer from ******uld be an entirely new casting if it's being made to represent one of the new dozers Cat just released. My Facebook page: NorCalDiecastCustomsClifton
