Joined: 4/8/2004 Posts: 98 Location: Darnestown, Maryland
Hello,
Did anyone else receive their IMC AC700's with many broken items? The mirrors. License Plates. lower valence, and two white washers were all found in the box along with a mounting point tip. I also had several broken axles between the two models. Just wondering if I am the only lucky one that this has happened to.
Greg
Mammoet one yes. Sarens and Demag one not.
Thanks,
Mammoet I recieved had a rear suspension assembly broken ...but having said that it was a recognised problem by Mammoet and IMC and was replaced quickly. Very impressed with all involved in the replacement.
I had a menagerie of parts in mine, from checker plate to license plate and and drive shafts, I re-attached everything going off photos and had a good conversation with IMC over delicate fine detailed parts
Sorry to hear so many broken parts on such an expensive model ;(..
I am in favor or all the small protruding parts not be attached to the model at all. They should all be separate in a bag. they should include a tube of water soluble glue. For some of us like me, i would rather not even put up the small parts if i have a choice as not to have any damage.
