Does anyone have any pics of a size comparison. Also wanting boom section comparison. Thanks in advance.
Rocky100370 wrote:Does anyone have any pics of a size comparison. Also wanting boom section comparison. Thanks in advance. I don't have my lr1750 built so i can't compare it directly to the lr1600 i built to the lowest configuration. but i can tell you that the boom section on 1750 is very slightly bigger. What's your thinking?
Joined: 8/27/2014 Posts: 321 Location: Canada, Alberta
Check out this review, he has it beside the 1600. Don't know if it works for you. https://youtu.be/81ODe6WDIWU A Millwright..... in Alberta.
Thanks Alberta......Just what I needed.
LR1600, L 1750, CC8800 Boom sections. LR 1750 section is 14m, 1600 and cc8800 12m. Hope that helps ;) These boom sections are very big btw, the cc8800 boom section is almost as big as some 50ton cranes
Thanks wildpig. That really helps!
