Joined: 9/5/2021 Posts: 20 Location: Las Palmas, Islas Canarias, España.
Good morning! After many tests and configuration changes I have managed to obtain my flexible material tires in scale with an acceptable result :d/ , the only thing that I have to polish the inner face of the tire to remove the marks of the supports...
Did you cast these yourself or were they purchased?
What model machines will these tires fit?
Dex wrote:Did you cast these yourself or were they purchased? Hi Dex, I do. Having a picture of the tire track and the measurements or scale, I can do it, even if it's a custom tire track.
RMS Models wrote:What model machines will these tires fit?
Hi RMS Models, the four that are the same, it is an order for a CAT 980C scale 1:50. The other three are test models with different tire tracks.
Will you be marketing these? Thank you.
Still Plays with Toys
Gd10r wrote:Will you be marketing these? Thank you. Hi Gd10r!, yes... I can do for sale but little by little because my machine can only do two at a time when the tire diameter is less than 40mm. and the manufacturing time is 2 hours.
Are you 3d printing these or casting them in a mold?
Dex wrote:Are you 3d printing these or casting them in a mold? Hi Dex! It is by 3D printing with flexible resin, that is why in manufacturing timeā¦ if you tried to reduce the time, this resin offers a lot of resistance and the stepper motor loses steps. You could increase the layer thickness which is now 0.05mm. but I don't know if it would lose quality... I would have to try...
