Highpoint Garage; King Kong will be reborn UPDATED 2/16/2008 Options · View
Brian S
Posted: Friday, February 08, 2008 4:42:58 PM
Our 1982 International Paystar is currently in Elkhart, Indiana at Bill Bottoms (B&B Industries)getting a little work done to it. We had always said if we did build a rotator; We would build it on a monster chassis. Well we couldn't think of a Bigger & Heavier Chassis than KONG. Besides Kong has a tradition to uphold. When it was built new By Bill Bottoms (Then Challenger) It was the largest manufactured wrecker in the world. So we figure it can capture that title again as the largest manufactured wrecker in the world.
It has ice cold A/C, Air Seat, Music, CB Radio. Excellent Heat, Tinted Windows, Heated Mirrors, Heated Fuel/Water Separator, and a Heated Air Dryer. It has an on board battery trickle charger that can get plugged in as well as an Engine Block Heater. It has a trunk mounted Motorola System with integrated Telephone System. We are having Cameras Installed
Kongs Chassis was originally intended for EXTREME oil field use. The Chassis, Suspension.. Driveline, Cooling and Motor were all were the heaviest and largest available at the time. It has a Cummins 330. Kongs chassis has 1/2 inch solid steel cross Members every 2.5 feet right to the rear. The triple railed chassis is simply put; Massive The new body will be fish plated to it's new Sub-frame. it only has 21,000 Miles on it. It has a 32,000 lb front axle. Dual Hydraulic Power Steering Boxes. Front axle Torque Rods. 1400 X 24 front rubber. 20 Speed Quad Box Transmission. It has a Super Low Gear and on the highway it will run between 65 & 70 MPH. It also has Dual PTO's. 65,000 lb Rears on Rubber Block Suspension and 1200 X 24 rear rubber. The chassis will be stretched and a third axle with 1200 X 24 rubber will be added. When all is said and done the total length of the truck will be approx 40 feet long.
The 45 Ton Challenger body is being removed and will be for sale by B&B. A new 80 Ton 360 Degree continuious spin 3 Stage Boom Rotator will be added with aluminum body. It will be built as a 100 ton unit but be certified at 80% of its capacity for insurance purposes. Optional dual turn table drive motors which will allow the rotation of the boom under full Load. 4 Upright Outriggers. Optional Rear Hydraulic Winching Spades. Optional 65,000 lb. Two Speed DP Winches with 7/8 Cable with Air free spools & Air tensioners. Optional 25,000 lb winches on the underside of the boom. Optional rear drag winch. Optional Wireless Hand Held Remote Controls. Optional 3 Stage 50,000 lb. Under Reach. Optional Onan Electric Start on Board Generator with Scene Lighting. And optional Rear Tailgate D-Rings.
We still have a few ideas were kicking around to add to it. But were still not to that point yet. It is going to be BIG & BAD. We delivered KONG to B&B Industries (The Big House) a few weeks ago. King Kong II should be in Jersey the end of March or early April. Myself and Steve Avella will be making a trip out to Indiana in a few weeks for a tour and to inspect the construction at the half way point. And than again to pick her up and bring her back home to Jersey. I will be posting pictures of the progress along the way and the trek home
Bri
Brian S
Posted: Friday, February 08, 2008 4:45:16 PM
After removing all equipment & Getting ready to leave Jersey
Fueling Up In Ohio
On The Road To Indiana
Arriving At B&B Industries... Kong is Home again .. Back to it's maker
It all begins somewhere
UPDATE: 2/12/2008. Kong is offically in the Building! The truck has entered a bay in the building. The onboard generator system and telescopic scene lighting has been removed as has been the fuel storage for the generators. The lower side boxes and lower tunnel box have also been removed. The rear tires are off and they started burning off the bolts that attach the wrecker body subframe to the chassis. The truck will be going to the chassis department next for the chassis stretch, additional cross members and the third axle. Will keep you all posted.
UPDATE: 2/13/2008 Engineer's Priliminary Print and Kong Specs
UPDATE: 2/16/2008 King Kong's Slewing Gear and Base Plate
Posted: Friday, February 08, 2008 4:58:24 PM
So what holds the current title as largest manufactured wrecker?
Brian S
Posted: Friday, February 08, 2008 5:00:57 PM
Brian S
Posted: Friday, February 08, 2008 5:13:21 PM
Tenwest towing in Bakersfield, California and George Logan in NJ have B&B 80 Ton Rotators that arent as optioned out and on as big a chassis. Tenwest's is on a KW W900 and Logan's is on a Pete 379. Steve Avella and George Logan are long time friend and Logans has helped us spec the the truck. The truck designed and build is based theirs and improved upon. The two trucks only have 2 50,000 lb winches and not the 65k plus the underside 25k ones. They also dont have the rear winching spades that ours will have. I have some pictures of Logans unit and tenwests that i can post later
Posted: Friday, February 08, 2008 5:39:19 PM
Look forward to the pics.
D5G
Posted: Friday, February 08, 2008 5:55:14 PM
Brian S
Posted: Friday, February 08, 2008 6:45:51 PM
George Logan Towing's Rotator
LatticeCraneMan
Posted: Friday, February 08, 2008 9:58:11 PM
Nice pics Brian especially Logans will be interesting to see Kong's conversion !Is Logans a slider ?
Chet
Bobm2004
Posted: Friday, February 08, 2008 10:48:54 PM
Groups: Member , Moderator
Hot damn that sounds sweet and the pictures of the Logan crane is fantastic!! I love the heavy wreckers. Please build progress picture would be MOST WELCOME!
Bob
Bobs Cranes
Brian S
Posted: Friday, February 08, 2008 11:53:17 PM
Chet
Chet,
It is only a rotator. NRC is the only company that makes a sliding rotator. NRC units come in 40 50 ans 60 ton capacities. B&B units from regular wreckers to rotators are all massive, hand built, and the biggest trucks in the industry. Miller Industries builds cookie cutter trucks on an assembly line under the Century, Challenger, and Vulcon briands. It would take 3 Miller trucks to do what you can do with one B&B
LatticeCraneMan
Posted: Sunday, February 10, 2008 10:27:12 PM
Interesting info thanks Brian !
Chet
Brian S
Posted: Tuesday, February 12, 2008 8:03:25 PM
see the second post in the discussion for the update info and photos
Rcguy_18
Posted: Tuesday, February 12, 2008 8:54:25 PM
Brain, now this is getting my attention. I plan on following this for ideas for on a rc wrecker of this caliber in the future.
http://www.rcguyfarms.com 1/16th scale shelf model to rc converter
Brian S
Posted: Wednesday, February 13, 2008 9:16:08 PM
2-13-08: added engineers drawing
towoc999
Posted: Thursday, February 14, 2008 12:18:20 PM
Hi !
simply AWSOME , by the way NRC industries are right in my backyard !!! I go there pretty often and my neighbord works there !!!!
The Frenchman
Ryanwtod
Posted: Thursday, February 14, 2008 12:43:07 PM
I wish I could talk my fire department into picking something like this up. That would be awesome. Throw in some pre-piped jaws and maybe a compressor or cascade for air tools.
Christian
Posted: Thursday, February 14, 2008 1:16:26 PM
its a beautiful machine. i love the Logan one too
however i am not sure the title "largest wrecker in the world" would be very correct, oilfield chassis or not... i think of Aramco using C500 Kenworth as Wreckers, i think of the huge Falck 10x8 Actros in Norway or the 10x8 MAN there with twin engines, i also think of converted MAN 8x8 from the US army working as wreckers and last but not least converted Scammell S24 and diverse Terbergs...
edit: i think the title goes to this one. Norway, MAN 10x8/6+2 (talk about an axle config!). twin engine 420+380 hp, max lift cap. 160 tons.
http://www.hansebubeforum.de/showtopic.php?threadid=6006&highlight=norwegen&s=ee944523ab98117b35fe4108aaeb1846
TimT
Posted: Thursday, February 14, 2008 4:28:46 PM
Yep, I would say as far as on-road wreckers go that one takes the prize!! What a monster.
LatticeCraneMan
Posted: Thursday, February 14, 2008 8:58:22 PM
Actually the largest would be "The Terminator" a father and son built it on a six axel Oshkosh mixer chassis has a actual crane boom !It was featured on the TRUCKIN USA tv show on the TNN couldn't find any pictures of it but the mixer platform is on HANKS trucks site ! Awesome rig !
Cool drawing Brian and shop pics.
Regards
Chet
