Update, a third variation. A week ago I got my third Liebherr A 904 C from the Liebherr Dealer here in Holland. This model has become a R 904 C with the tracks of a Liebherr R 924Compact which match out pretty good according to the official brochure. I'll be making two more models, a crawler High-Rise and a wheeled High-Rse. Just a bit higher than normal, but enought to have the really stand out. The trio on a row...   From the top...
Joined: 2/8/2007 Posts: 1,834 Location: Eatonville, Washington
I like the version with the 924 undercarriage! awesome!
Jimmy
Don't take life too seriously, you'll never get out alive!
A new variant, the A 904 C Leonard. Starting out...   And after attaching the boom, together with it's R 924 Compact brother.      Three new variants are already on the drawing board. -A 904 C High-Rise -R 904 C High-Rise -A 904 C HD with short stick for heavy (demolition) tools (i.e. Mike's 3rd member shear)
That's awesome. Your like a mad scientist.  Red
redscustomscalemodels.com
New custom. I never liked the crawler version that much, so I reinstated it as a wheeled machine. But with a difference. I removed the original boom, and replaced it with a modified boom of a Norscot A 904 C. Making a wheeld excavator with a hydr. adjustable boom and a lifting cab. I also supplied it with a coupler for pulling a trailer, in this case the semi-lowloader from Siku. The original quick coupler can also be fitted ro the stick, but for now I added a CMM-Schwerlast sorting grab. The stick has a width of 8 mm, so it can fit a variety of buckets / attachments. Here it is with it's smaller brother, the A 316.   Trailer coupler...  I plan on making a third kind of wheeled Liebherr excavator with a hydr. adjustable boom like this. But it will be a bit larger, A 954 C size to be exact.
As a multifunctional excavator, the Liebherr A 904 C obviously needs a variety of tools for various purposes. Here are a couple of photo's of this little but very versatile machine! The trailer is a Tekno container trailer. I just don't have a 40 m3 (52 yrd3) container yet, but this will be remedied in a few weeks time.  Different tools. Next to the Himobo Atlas-Copco shear is Brian Blackman's new kit, looks much better, and with the so called Japanese screws I used to put it together is much stronger than it's Himobo counterpart.  Extendable lifting arm, still needs a small hook and a concrete bucket...  Brian's new shear. Wonderful kit, comes together very easily, and you can choose between an adapter for an 8 mm boom or a 6 mm boom. I put the 8 mm one on mine, so it will fit the A 904 C's stick. It's also a lot cheaper than the Himobo model, which is almost three times as expensive. Yup, I'll definately get a couple of more kits in the near future!!  Very wide opening...  Closed...  Brian's rubble bucket...   From the side...  In theory Mike's 3rd member shear would also fit the boom, but it's much to heavy for the A 904 C. I've also planned a pallet fork attachment for this excavator.
Joined: 1/20/2003 Posts: 1,922 Location: saginaw michigan
Remko, you are correct about mikes shear being too big for a 904. Something that may help you out though. I hear rumors of a demo guy making a series of new shears.
Charter Member, QBall Fan Club http://www.facebook.com/group.php?gid=42336642940&ref=ts
Joined: 7/21/2007 Posts: 1,767 Location: Derbyshire,UK
They all look great! I cant wait too get my hands on a Brian Blackman Shear! Will look awesome on a EC240. Just one thing....dont you think the one on rail bogies would be a bit unstable on a real machine?
Joe
turbo21835 wrote:Remko, you are correct about mikes shear being too big for a 904. Something that may help you out though. I hear rumors of a demo guy making a series of new shears. I've already got a solution for that, I'll make a special adapter from a leftover stick, and make it a 2nd member shear. But in that case it will go on a monoboom excavator, probably the R 916 Advance when it's released. I've already planned a few customs based on that model, including two different wheeled excavators. Rumors hey... JoeS1989 wrote:They all look great! I cant wait too get my hands on a Brian Blackman Shear! Will look awesome on a EC240. Well, it doesn't look too bad at all... Just to give you an idea Joe!  JoeS1989 wrote:Just one thing....dont you think the one on rail bogies would be a bit unstable on a real machine? Perhaps it might, but I have tried it out on a short piece of O-gauge track (slightly wider than the NZG track) and it holds quite well. I've also widened the track gauge on the excavator, as well as bigger rail wheels.
I've finally added new wheels to this old Siku trailer. Perfect for carrying attachments or cargo. Sides can be folded down for easy access.
I made some changes on my A 904 C with Leonard boom. I replaced the original (small) outriggers with those of the A 954 C and replaced the tires with smaller ones from Tekno, giving the model a whole different appearance.  Equipped with a sorting grab...    Second, similar, undercarriage is already there. This will be fitted with an A 904 C upper carriage from Norscot.
remko this is really awesome that you have taken the time to build all of these different combinations! Very interesting! Thanks for taking the time to post this!!
I do have a question though, do the attachents for the leonard boom fit the same coupler that is supplied with the case CX130? They look to have the exact same hammer, so I was just wondering...
Jimmy
Linkbelt or Cat wrote:remko this is really awesome that you have taken the time to build all of these different combinations! Very interesting! Thanks for taking the time to post this!! No problem! Linkbelt or Cat wrote:I do have a question though, do the attachents for the leonard boom fit the same coupler that is supplied with the case CX130? They look to have the exact same hammer, so I was just wondering... They might fit, but as I don't have the Case CX 130 I can't fit them. Do you have the stick width of the CX 130?
Something I've always loved was a material handler with a normal dipper and a demolition attachment. Well, I've been planning to make these for a long time now, and here's the first prototype. The future models will be a Sennebogen 835 M MultiTool (with short boom and adapter for a normal stick) and a Liebherr A 954 C. But for now, here is the A 904 C. I replaced the three piece boom with a monoboom of the R 924 Compact, but kept the original stick of the Norscot A 904 C. This was drastically shortened however, as well as fitted with two Himobo quickcouplers glued together in opposite direction. The undercarriage has been replaced by that of the Sennebogen 835, fitted with smaller Tekno tires and big outriggerpads from the A 954 C.    But what would you carry on that... Well... Mike's thirdmember shear of course!! In theory the model could carry all the tools and attachments I have for my R 954 C, but this might not always be useful.
Joined: 1/23/2007 Posts: 3,636 Location: Staten Island NY
Very cool! I always like reading your topics.
Really nice! I love to see what you're doing with all your Liebherr models!
But, does the stick-mounted quick coupler for your shear exists? It looks a little bit unsusual...
Antho wrote:Really nice! I love to see what you're doing with all your Liebherr models!
But, does the stick-mounted quick coupler for your shear exists? It looks a little bit unsusual... Nope, I used an adapter from forummember JanH and modified it to fit the shear, this is glued to a Himobo 9,5/9,5 mm coupler, so it will fit the Liebherr R 954 C. Model has been modified even further as we speak, it's now fitted with a dozerblade in front of the forward outriggers, and also has a normal stick, which I modified from a A 904 C MH stick. So it can now also hold smaller buckets (from Brian Blackman for example), the original A 904 C MH sorting grab or a small hammer. Multi-functional machine, just the way I love them!! I've already begun preliminary work on my next project, a Liebherr rotating tele-handler. Using an upercarriage from a Liebherr A 314, undercarriage from the A 904 C MH and cab and boom from the original Liebherr telehandler from Brami.
Sorry, I know that the model is a custom but I meant, does it exist in real life?
Antho wrote:Sorry, I know that the model is a custom but I meant, does it exist in real life? That depends. In Germany, similar machines are quit common. And Sennebogen has a new one from their "D"-series equipped with a Multitool as well. So, yes, the basic principile is used on various machines from different brands with large demolition tools. But if this particular machine exists is doubtful. One of the machines that served as an example is this Liebherr A 900 C Litronic with MBI SH310R scrapshearAnd on the German Bauforum24.biz this photo has been posted from Intermat 2009 in Paris, although this is a R 924 C and not a wheeled excavator. Shear is a Labounty MSD 2000R (so if Eric has his shears ready, I'll surely model this using the Liebherr A 924 C model from NZG)
